Question about Frigidaire Refrigerators
Have been told that problem with sealed system restriction of Frigidaire side by side not feasible to repair also costing upwards of $1000 to possibly repair. True?
Mike, the work on the sealed system without changing a compressor
takes around 2 hours if everything goes well. Plus a lot depends on the
unit you work on including the type of the system R-12 or R-134 A. Just
to vacuum the system takes around 30 min for good quality repair work.
Evacuating, Brazing, Recharging, Checking for Leaks and Restrictions,
Cleaning, Taking your tools out and in.
Posted on Dec 03, 2012
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Depends on what needs to be replaced.
Posted on Nov 30, 2012
3 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: Repair cost. Frigidaire FRS26R4A Side by side
  • no, it should be around $300-$400. but i would consider replacing the machine b4 i would spend $700.
  • repairclinic.com has the whole compressor kit for your refrigerator for $165.80. comes with start switch, tubing, new filter and everything. fd082f7.jpg it shouldn't take more than an hour to change the compressor and recharge the system. 134a freon is about $10 for the amount you need.
Item #
1376919
Price
$165.80
Posted on Jul 05, 2008
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator and freezer not cooling
That depends on who told you that answer and if the evaporator coil is in need of repair. The answer to a leak in a sealed system is yes and most likely to be in the evaporator coil because some companies use epoxy to attach the aluminum coils to the copper tubing. And the constant changes in warm to cold in that area cause the connections to crack. Hope this helped answer your question, Thanks, Sea Breeze
Posted on Jun 16, 2009
How do I completely open a partially opened freezer drawer?
Hello Laura;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerators with freezer drawers are nice up until the time that you need to call a service technician, and find out it cost about 40% more than a top or side by side refrigerator to repair.
If you leave your freezer drawer not completely closed, outside warm air enters your freezer and you get Ice build up on the rail system. It is difficult to see if the freezer drawer is completely closed because the fresh food section doors above block the view.
If you can pull the drawer out part of the way, use a hair dryer directly on the rail system on both sides in a effort to melt the restricting ice. Take your time. This may take several hours at which time you will push and pull on the drawer every 30 minutes until you break the rail system free from ice restriction.
After you have the door free, with a kitchen spatula and a hair dryer heat the gasket around the freezer door gasket pulling the gasket out to repair a possible crushed door gasket and not having a goo seal.
I have gone on service calls where the rail system ice was so built up, all I could do was to advise the customer to unplug the refrigerator for 36-24 hours to clear the ice from the rail system.
This is a common problem with drawer freezers. Next time get either a top mount refrigerator freezer or a side by side. Lower repair cost and more reliable.
Mar 06, 2016 | GE / Profile PFSF6PKXBB
How to install seal side seals on frigidaire dishwasher model number FGCD2456
Hello Dwight, thank you for your inquiry!
From my understanding you need helps installing the side seals on your Frigidaire dishwasher, FGCD2456. If your seals have been properly installed there may be another gasket causing the internal leak. Is it coming from the corner of the sides? This could be a possible issue with the lower door gasket or the door itself. I would check to make sure it is properly sitting on the hinges and not adjusted incorrectly. You may need to have a professional technician out to perform a proper diagnosis. Hope this help you with your repair. -Matt
Jan 04, 2016 | Frigidaire Washing Machines
Wha is the Frigidaire FSC23F7DSB warrenty
Good Morning Friend,
I understand that you want to know the warranty on your Frigidaire refrigerator, model# FSC23F7DSB. There is a one year warranty, where the manufacturer will pay all costs for repairing or replacing any parts of this appliance which prove to be defective in materials or workmanship. This does exclude original and replacement ice & water filter cartridges (if equipped). Original and replacement cartridges are warranted for 30 days (parts only).
There is a second through fifth year warranty on the cabinet liner and sealed system. This means the manufacturer will repair or replace any parts in the cabinet liner or Sealed Refrigeration System (compressor, condenser, evaporator, drier and tubing) which prove to be defective in materials or workmanship. Check with the manufacturer for any further details. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FSC23F7DSB Stainless Steel Side...
Low side pressure high
You have a restriction in the sealed system. Junk the fridge.
Dec 04, 2013 | Frigidaire FRS3R4E Side by Side...
How much does it cost to replace the seal on a Kenmore top-loading washer?
Please check this site and link from where the seal can be purchased and gives you an idea to replace the same.
click on:Door seals
Jun 27, 2012 | Kenmore Washing Machines
Compressor failed and was replaced by technician. He now says the evaporator is clogged and will have to be replaced. Will I continue to have problems after this next part replacement since the sealed unit...
It(evaporator) may have been the reason for the original failure. If he did a poor job brazing the new compressor it could have caused the restriction. If he failed to replace the filter drier it could have clogged. If he did not vacuum the system from the high and low sides it could have caused a restriction.
He could open the system,replace the filter drier,blow nitrogen through the high and low sides to clear a restriction possibly without having to replace the evaporator. Then pull a thorough vacuum and recharge refrigerant with a weight scale.
Aug 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator and freezer not cooling
Jun 12, 2009 | GE GSS25SGMBS Side by Side Refrigerator
I have a frigidaire model FRT21LRGW, the compressor was changed in 2005, evaporator& heat exchanger was changed in jan.2009. Last week apr.2009 the unit started giving problem AGAIN. Freezer and fridge not...
Possible leak in the sealed system. Make sure the technician pressurizes the system with nitrogen, changes drier, evacuates to 500 microns, then weighs in the correct charge.
Apr 23, 2009 | Frigidaire FRS23KF7AB Side by Side...
Item #
1376919
Price
$165.80
Jul 04, 2008 | Frigidaire FRS26R4A Side by Side...
Repair cost.
I have been working in this field for nearly 48 years and I see to many times where people doing service do not have the customers best interest at heart. Get a second opinion and don't tell them what the other quoted.
Refrigerators Logo
153 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
