Question about Samsung R600
Ccc.exe when trying to shut down it wont shut down due to ccc.exe
    Problem Solver:
  • 9 Answers
Ccc.exe is a process for Catalyst Control Centre: Host application, see what is ccc.exe So, try to un-install Catalyst Control Centre and install newer version.
Posted on Dec 03, 2012
How do i fix an application shell.exe error on a pkc0pc - 5.0 gps
your going to have to send it in if it want reboot thats all you can do
Jun 04, 2014 | GPS
Google chrome wont shut down and n access to sites
Hit CTRL+ALT+DEL and Click the 'Process' tab and look for Chrome.exe process and then click 'End Process'. Chrome should exit.
Now try to start Chrome again.
If still fails, Restart your PC.
Oct 17, 2012 | Google Chrome
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Hyundai Autonet PND-3520T. Wont navigate.
There is a solution, what is the path of exe file (from the SD card and from internal storage)
Oct 29, 2009 | GPS
The status of my printer says error. How do i fix it.
insert the software cd, and brows the cd. there will be an UTIL folder inside the cd,inside util there is a ccc folder,and inside ccc folder we have uninstall L1.exe file.
unplug the printer usb cable first and then double click on the uninstallL1.exe. it will uninstall the basic driver from the computer and then restart the computer and printer.before that ple take out the cd.
then try to do an add a device by inserting the software cd of the printer.
Oct 22, 2009 | HP Photosmart 3210 Printer
My ducted dometic roof unit wont cycle on when i try to reset t stat it reads ee i think my upper board is bad
The upper board is a possible problem, however before you drive yourself crazy after purchasing a new one and it not working, try removing the CCC from the wall and obtaining a piece of the cable that connects the upper unit to the CCC. You should be able to get this at any local Dometic repair facility or dealer. With this piece, plug the CCC directly into the upper control and try resetting it. If this does not work, then it is either the CCC or the upper control board. You can also try turning all the dip switches to off in the control board and resetting the CCC and then turning them back on to their original position and resetting. This will sometimes work if the two just lost communication.
Hope this helps,
Jeff
Rate me please!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
I m unable to shut down my inspiron..............every time i does it , it gets stuck......& i have to shut it down by power button......plz help me out
You have a process that is not shutting down,Try this,Hit control,Alt,Delete and open the task manager,On the process tab,you can see what is running,End task on everything BUT Explorer.exe,logon.exe,and The svchost.exe(you will have a bunch of these)After you have end task on everything else,Try and shut down.
Jan 06, 2009 | Dell Inspiron 710m Notebook
Can't open or remove due to mmjb.exe shutdown in unusual way
You don't give much information about what your problem is and unfortunately part of what you did write was truncated.
...If I understand your problem you need to uninstall and reinstall, but can't due to a locked file,
I have two suggestions one FREE program is Unlocker Assistant. (Google it) the other is a nice little FREE utility you can try. Install Microsoft "Windows Installer CleanUp Utility" http://support.microsoft.com/kb/290301/en-us
If you find (PROGRAM NAME) listed just hit the delete button.
Then do the normal uninstall.
May 28, 2008 | Musicmatch Jukebox 7.0 (1575956454) for PC
ATI graphics card 9600XT crashes system
Ok, If you havnt already (since putting the new card in) Reinstall Direct-X 9 onto your system, then retry the Catalyst drivers.
If this fails, then the next time you boot, go in through safe mode, goto Start - Search For Files And Folders
When the search window pops up, under the search box is an advanced search. Tick "Search Hidden & System Files & Folders"
Do a search for "CCC.exe" and delete all found.
The Catalyst Control Centre (CCC) causes alot of issues for alot of people for no reason. But if that can be isolated it will help.
Apr 14, 2008 | ATI RADEON 9550 Graphic Card
Problem
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=219,E=0000000000312612672,K=2651,Sxi=0,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(10053)
Jan 09, 2008 | Creative Labs Zen Digital Media Player
Samsung R600 Logo
99 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
