Question about Kitchen Ranges
E1 f5
The oven door will not open and there are two indicators--E1 and F5--on the console. Tried powercycle, tried starting and canceling auto clean--no change.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
  • Disconnect power from unit.
  • Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors.
  • Replace door switch.
  • Re-apply power.
  • Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  • Posted on Nov 30, 2012
    SOURCE: locked oven door
    The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
    Posted on Nov 04, 2006
    SOURCE: E1 F5 error on self cleaning oven
    Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
    This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
    Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
    its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
    if not our suggestion would be to replace the part....
    good luck...
    if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
    Posted on Aug 10, 2009
    SOURCE: Whirlpool oven door won't unlock after cleaning
    The motor that controls the door lock was bad. Go online and order a new motor based on range model number. User can fix if reasonably handy with tools.
    Posted on Jan 08, 2010
    blueextc3221
    • 15935 Answers
    SOURCE: E1 F5 displays cannot use the oven whirlpool
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
    Posted on Oct 01, 2010
    blueextc3221
    • 15935 Answers
    SOURCE: self cleaning F5 error
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
    My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
    E1 f5 code oven - YouTube
    ? 1:51
    https://www.youtube.com/watch?v=5F1vwVpmG9U
    Dec 28, 2014 - Uploaded by Jay Dornbos
    Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
    Nov 23, 2016 | Whirlpool Ovens
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    4 Digit Failure Codes
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    Tip
    F5 - E0 Door Switch
    Two digit codes:
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    What can I do for F5-E1 situation
    Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
    Whirlpool Oven Common Problems and Causes
    Jan 08, 2015 | Ovens
    Trying to get gas self clean/oven to start. Getting error E1 F5.
    E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
    Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    E1 F5 Error on Whirlpool Accubake Oven
    The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
    Apr 07, 2009 | Ovens
    Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
    F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
    Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
    F5E1 error
    Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
    >>Exception Note:<<
    Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appear, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
    E1 f5 error code whirlpool gr399lxhs
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
    Mar 25, 2008 | Whirlpool GBS307PR Electric Single Oven
    Locked oven door
    Oct 31, 2006 | Whirlpool RF378 Electric Kitchen Range
    Kitchen Ranges Logo
    64 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
