Question about Video Cameras
Canon uc-v200 8mm Video Camcorder connect to Computer
Can I copy from Canon uc-v200 8mm Video Camcorder connect to Computer
5 Suggested Answers
  • 203 Answers
SOURCE: transfer my minidv camcorder film onto DVD
i assume your using firewire-not usb right? use windows movie maker in xp or vista -should transfer ok if machine is pretty current-if very underpowered with little ram memory expect problems
Posted on May 20, 2008
snax123
  • 18 Answers
SOURCE: how to connect
Unfortunately those old camcorders generally aren't compatible with modern computers. But don't give up hope, you may be able to find back roads and such to get it onto a computer. I'd suggest doing some research on the computer. Hope that helps.
Posted on Apr 13, 2009
SOURCE: how to download video from Canon DC22
Please give me Degital JVC PC 810 Driver
Posted on Mar 03, 2010
  • 269 Answers
SOURCE: I have canon zr85 camcorder.
You require a firewire cable and an application that can capture the footqge such as Windows Movie Maker.
Posted on Apr 15, 2011
Does theCanon UC-X2 camcorder play 8mm tapes?
Hi-8 camcorders might be backward-compatible for playing tapes. I bought a model which could be switched between the two modes - Sony DCR-TRV355E.
Jan 31, 2014 | Canon ES400V Camcorder
Need to download videos to computer. Help?
Couple ways to do this:
1. Camcorder should have come with a cable to connect to computer. If you connect it Windows should prompt for import.
If not go into folder where videos are store on camera, select the videos, copy/paste them into folder on computer.
2. If your computer has an sdhc card slot on it remove the card from camcorder and put it into computer. Again Windows should prompt for import, or you can copy videos manually.
There's also plenty of other software designed for importing and managing photos/videos, that may be a good option.
If you are unsure, having someone help you through the process in person may be good.
Sep 04, 2013 | Canon HFR400 Camcorder -
My sister took a video of my dghters wedding last month how do I go about getting 2 copies put on a dvd?
Connect the camcorder on your computer. Copy the files on your hard-drive or you can copy it straight to a blank DVD if you have a DVD-writer. Just repeat it again to have 2 copies.
May 15, 2011 | Canon Video Cameras
I have a Canon 7.4V video camera and want to connect my camera to the computer. How do I do that?
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Hope this has helped you.
www.austintelstarservices.com
Sep 04, 2010 | Canon Video Cameras
How to over come error code no. 2881
Good day,
I like to know how to connect my canon camcorder UC-V100 being analoge to my computor
thks
Jun 04, 2009 | Hitachi DZ-MV550E DVD Camcorder
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Nov 07, 2008 | Video Cameras
Transfer my minidv camcorder film onto DVD
May 19, 2008 | Canon ZR800 Mini DV Digital Camcorder
Video Cameras Logo
93 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
