Question about Cell Phones
I locked my phone then the touch screen didnt work I can't sen texts or access anything because my screen does not work! It is not reacting to my touch HELP!
  • Cell Phones Master
  • 17,115 Answers
Clean the screen, pay close attention to the edges, use a q-tip if you have to. Most likely the screen is sensing dirt or dust or grease and not your finger
Posted on Nov 29, 2012
SOURCE: HTC messaging disappeared
I had this problem ,also no notifications of voicemail as well as not being able to acces the messaging screen. I was just about to send the handset in for repair and decided to remove the 4gb micro sd card .turned the phone off ,removed the card,turned it on again ,bam messaging works again !! hope this can help someone else too :-)
Posted on Apr 13, 2009
mayra6
  • 3 Answers
SOURCE: LG Prada Touch Screen Freeze
just turn it off and on again
thats the only solution i know at the moment
its a real pain in the arse but wat can you do
Posted on Jan 21, 2010
popsgifts
  • 160 Answers
SOURCE: my envy touch inside screen is not working, but
Near the joint of the phone, on the inside, there is a tiny hole that hides the switch for the inner screen...it's location is indicated by the small nipple on the upper-half of the phone, again near the joint/hinge.
This correlation between the nipple and small hole acts as the auto-off switch for the inner screen when you close the phone.
Inside the hole is a thin plastic membrane with a flexible copper contact underneath called a contact switch, and nicknamed a bubble switch for the general appearance (the shape is similar to a small bead of water on a waxed car).
Normally convex shaped, these contacts can be pressed (deformed) into a concave, which means that, as a switch, it is still making contact as if the phone is closed.
This happens often when the closed phone is pressed hard, and some never realize that they did it (sat on it, etc.) until the screen is blank.
There are 2 ways to pop the switch back out; The first is the proper way, by opening the case and accessing the circuit board...but the other way is the first-try method that you as a user can do easily before seeking a service center:
Using a non-sharp piece of wire or stiff plastic (a ball-point pen if it will fit, and if it won't a bread wire-tie folded tightly in half, or a straw from a broom, etc.), poke gently into the hole and run the point around in a circular pattern to cause the deflated bubble to pop out.
The screen will/should flicker while you're doing this...and will come on when you got it.
Posted on May 01, 2010
  • 320 Answers
SOURCE: My touch screen won't work.
Try to turn off the cellphone, remove the battery for 5 minutes then re-insert the battery and try again. If the touch screen still doesn't functions try to restore the factory settings.
Posted on Nov 19, 2010
  • 30 Answers
SOURCE: my phone's touch screen is
A diagnostic list includes 1. performing a full device power charge 2. change the entire battery 3. Reset the device with the pin area provided to estblish default settings 4. refer to the user manual 5. contact technical support online for further asistance
Posted on Dec 05, 2010
Touchscreeen wont work
1. If you have a case on your phone it could be pressing on the screen which would not allow any other part of the screen to work.
2. You could need to do something as easy as taking the battery out for a minute and putting it back in.
3. If the wrong buttons are reacting to your touch recalibrate your touch screen and see if that helps.
If these things don't work you will need to call customer service persons
Apr 11, 2010 | Palm Pixi Cell Phone
When I turn my 60 gig PS3 on, it only gives me a black screen for about 5-10 seconds, then picture of 2 cartoon penguins in the top-left hand corner, and the rest of the screen has white computer text...
hold the power button for 5 seconds, a menu will popup to u chose to repair ur PS3, if it didnt work with u, do it all over again but this time go with format option and i will word :)
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
D980 touchscreen sensor is not working.
Please check if the screen is not in lock mode.
Sep 20, 2009 | Samsung SGH-D900 Cellular Phone
Broken touch screen
Sounds like a broken digitzer, this is the front fascia. You can bring it to a mobile repair centre and get it replaced, or attempt it yourself. Should however still be under warranty so can bring it back and get it fixed free of charge though you will have to wait several weeks
May 27, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Can you tell me how to access the front touch-screen full-keypad?
You can only have the front screen touch keypad when you touch twice (double click) in the area where you want to type. (for example when you browse on the internet, text messaging or adding contacts). If you can't use the touch keypad the phone will tell you (for example in MSN messenger, you have to work with the keypad inside the phone).
Apr 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Aug 21, 2007 | LG Prada KE850 Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
