Question about Hannspree Televison & Video
Hannspree tv shadowing
Just got a new tv and playing my ps3 on it and a few days later the tv seems to be doing what i can best descrive as a after affect was playing COD and a guy ran by me but he was more of a blur and was almost 3 of him but blended into one long smuge if i dont move is seems out of focus
Hannspree 28" tv video shuts off after on for a few minutes
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
Jan 12, 2013 | Hannspree HT09 28 in. LCD TV
Cannot get it to connect to monitor
Hi, What model Hannspree is it? you might have the resolution set too high for the monitor!
Sep 23, 2007 | Sony Playstation 3 (PS3) Console
Hannspree HF289H Black screen SIngle orange light once and completely unresponsive
There is two chance for theis problem. 1) there is missing voltage to the back light inverter boadr or 2) the back light inverer is faulty. Check the power supply volatge to the back light inverter board. Normally its 24v for all lcd back light inverters. If the power supply is ok then you have to replace the back light inverter board.
You can check is there is any picture on the lcd screen by the help of a tourch . light the tourch near to the lcd screen and wach the screen from different angel while the PC is in ON position.. in some angle you can see the shadow of picture if every thing else working fine except back light.
If so there is powersupply missing or back light iverter is faulty. You have to replace the back light inverter board with a new on because there is no repair possible with the board. Also the spares will very difficut to get.
Ajin
Apr 01, 2012 | Hannspree HF289HJB 27.5 in. LCD TV
What are the best settings for playing video games on PS3?
Use hdmi or companant cables.
1080i is the best resolution.
I would recommend 1080p otherwise.
Apr 25, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have the new smaller ps3 120gb when playing it starts the game over 3 times already
make sure you dont have firmware version 3.0 if you do you need to upgrade it version 3.0 broke alot of games but luckily a few days later 3.01 came out to fix this.
I would just goto system update and see if there is a new version available and install that before you start diggin to much into this problem.
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
Pink shadows
you need to get the HDMI cord.
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
73 people viewed this question
Top Hannspree Televison & Video Experts
Ricky Lee
Level 1 Expert
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
