Question about Element ELCHW402 40 in. LCD HDTV
40" element tv randomly shuts off during use
Shuts off randomly
My videocon bazooka tv (model:5415) swich off randomly during the watching tv. What is the problem? Find attached tv power supply circuit and suggest me what element in circuit should be replace?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Mar 24, 2016 | Element Televison & Video
I cant get digital channels on my element 40 inch element plasma t v why
Perhaps your TV is not compatible with the new digital signals you now get from your provider. But you should be able to get (buy) a digital receiver from your provider, that is can receive all channels and can be connected to the TV with a HDMI cable.
Apr 19, 2015 | Element ELCHW402 40 in. LCD HDTV
Tv randomly turns off. Not sure if it is overheating or if something is broken.
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
Mar 21, 2015 | Televison & Video
I tried to register my new Element Electonics 40" Model - ELDFT406. Says model # doesn't exist ? Also having trouble getting the tint setting.
so you shouldn\'t bother too much with it. I have the same model and it shuts itself off whenever it chooses to. I\'ve only had it since the 23rd of November, and it shut itself off after 2 days and maybe being on only 6 hours in those two days. It shut off the other day after 40 minutes. Read the reviews on Target\'s site, most people have issues.
On Facebook, the manufacturer said they would be adding this model to their site within a week, and that was around the 26th of November that they said that and it\'s still not on their site yet. I got mine at Target and I have 90 days to return it, so I\'m going to wait until TVs go on sale around the beginning of Feb and return it.
Dec 03, 2012 | Element Electronics HD LCD TV ELDFT404-B
Eldft406 HD Digital LCD TV.Just got it and the sound goes in and out.
I have this same one and it shuts itself off at random, one time after only being on for 40 minutes. It started within 2 days of it being set up and it was maybe used for 6 hours total when it first shut off. The remote hardly works too. Other people have the same problems with this TV, read the reviews of it on Target\'s site. I got mine at Target so I have 90 days to return it and I\'m waiting until around the beginning of Feb. when HDTVs go on sale again. I suggest you just return it,. You can\'t even find it on the manufacturer\'s website.
Nov 29, 2012 | Element Electronics HD LCD TV ELDFT404-B
I lost my booket for the element 40' flatscreen tv
Refer your problem to DIRECT TV to obtain a code
Nov 29, 2012 | Televison & Video
My 40" tv shut off
1. PSU (power supply unit) board problem, replace or repair
2. if your tv is CRT(cathode ray tube) type, chances are the horizontal output transistor is busted. Replace.
In the above problem, a qualified technician is required,
hope this helps ;-)
Feb 03, 2011 | Element Electronics Televison & Video
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Element ELCHW402 40 in. LCD HDTV Logo
266 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
