Question about Refrigerators
I have a kenmore elite model 106.54603300 condenser fan runs clicking sound at compressor
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
aasc
  • 1606 Answers
SOURCE: My Kenmore Elite trio has stopped cooling the
If you see frost on the back wall inside the freezer , then your condensor is working , which indicates you have a defrost problem .
Posted on Jul 11, 2009
aasc
  • 1606 Answers
SOURCE: Freezer not freezing, refrigerator warm, hear clicking sound
The overload/relay on the compressor is shorted . This is the piece with 2 or 3 wires connected to it , mounted on the compressor . The part # you need is 8201786 . Complete mounting instructions , come with this kit . Easily replaceable .
Posted on Oct 07, 2009
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
Dec 03, 2017 | Kenmore Refrigerators
Refridgerator is not cooling and the freezer not freezing. The cooling fan does run but it seems the compressor does not turn on. I'm wanting to test the capacitor to see if that could be the problem...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Kenmore Side by Side Refrigerator
My kenmore elite all fridge does not get really cold any more, only the fan seems to be running and maybe not the compressor, its only 2 years old
heatman101
Aug 10, 2011 | Kenmore Refrigerators
Not cooling, compressor and condensor coil fan not running.
It sounds like you may have bad starting components on your compressor. I would check your condenser fan motor for 120v. Or try to put a small box fan behind the ref blowing directly on the compressor to aid in cooling it. If the compressor kicks in then you know the problem is with your condenser fan motor and not your compressor. If the start components are bad you will usually hear a clicking noise from the compressor every 10-15 mins or so.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
I come home and water is on the floor due to my freezer not working. I think its a condenser problem; so I vaccum out my condenser coil and restart the condenser fan. But the condenser is still making an...
check that compressor is running. if your hearing a hum and then click you probably have a faulty compressor relay. most times you can pull it off and shake it and you will hear little bits rattle, well it should actually make no sound. but it could still be bad if compressor fails to run. compressor may or may not be warm.
Jan 21, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio = clicking and fan running constantly
Sounds like a problem with the compressor.  Get a service tech in.
Nov 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
