My toshiba laptop l-555 powers up but no hard drive memory or wireless lamps black screen
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
hey! chris thanks a gazillion man whew! i thought it was goner! man!!! it came right back to life following your steps ! once again thanks you saved me the cost of a new one!!!!
Hey thanks again just used this on another laptop worked like magic lady is pleased she thoughts she would have to trash it!
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
SOURCE: Apricorn EZ Upgrade II Cloned Drive Won't Boot - Toshiba P15 479
Basically this product does not do what it is advertised to do. You have to do a custom clone (not typical as suggested) and try to get an exact copy the drive you want to copy.
But... If you are upgrading to a larger drive you will now have to do a diskpart as an external drive in order to get the complete upgrade your drive.
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
