Question about Radio Shack (15-2147) Remote Control
I need instruction on how to program this to work my dtv box
I have no cable how do i program this tv set?
I assume you also have no satelite dish. You are probably on an antenna (or rabbit ears). If you don't already have one, you need a DTV Digital to Analog converter box. I am assuming you want to snag broadcast signals from the air, like in the good old days before the massive digital conversion of most broadcast stations. Might be hard to find one in retail stores, but start with WalMart or Best Buy, and if that fails you might check eBay (I think it is too late to get the government rebate which absorbed almost the entire cost of the box, but you might check around on Google searching on 'DTV Digital Analog Rebate'). The DTV converter will change the digital signal now being broadcast on most stations to an analog signal that your antenna connection will recognize. Without a signal, you can't program the channels because the tuner has nothing to latch onto. After getting a signal you just follow instructions for your TV to search for channels -- if you don't have instructions you might have to play around with the menus on-screen until you find what you need, but essentially it will be obvious when you see it ... the on-screen instruction will say something like select or program channels, and may let you choose manally or search automatically (choose automatically after hooking in the DTV converter to find all channels). Hope I understood your problem, your description is a bit vague.
Aug 29, 2011 | Televison & Video
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does a CT-27614A need a digital converter for antenna?
I hope this soultion is helpful.
Feb 12, 2009 | Panasonic Televison & Video
Dtv universal remote
I'm using a universal remote with code for an LG 0178 (or 101780 AND IT WORKS
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Radio Shack (15-2147) Remote Control Logo
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
