Question about Home
KYO Zoom toilet accesing the cistern
KYO Back to Wall Toilet Suite (KITKYOBTW)
Zoom cistern keeps on overflowing
Posted on Aug 30, 2017
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
  • 396 Answers
SOURCE: Water leakes continually into the toilet bowl from
the flapper is not sealing or the water level is set to high and you will need to lower the float. you will not need any parts to adjust the water level and the flapper is under $10.00. Click on the bellow link to see the parts diagram. http://www.google.com/imgres?imgurl=http://www.hometips.com/articleimages/20070913131246_plb_toilet_componentsdiagram1.gif&imgrefurl=http://www.hometips.com/how-it-works/toilet-plumbing-diagram.html&h=428&w=353&sz=34&tbnid=-jD50OHr-goZAM:&tbnh=247&tbnw=204&prev=/images%3Fq%3Dhow%2Ba%2Btoilet%2Bworks%2Bdiagram&hl=en&usg=__WY8gJuebzTLRKmtC489ClS9UH3s=&sa=X&ei=AikpTJXJHIK0lQf66vSCCA&ved=0CBsQ9QEwAA
Posted on Jun 28, 2010
How does the cistern fit onto the toilet and connect to the water outlet. Does it got onto the toilet seat if so how do you connect the water supply?
normally the cistern is mounted to the wall and the pipe to the bowl (pan) is just connected by a rubber grommet at the pan inlet and a threaded nut that compresses a rubber ring in the cistern end
water supply is via a hose from the isolator tap next to the an up to the pipe under the cistern
Aug 26, 2017 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
How do I install a replacement toilet suite
it is really a job for a plumber
however get the same sort of pan as you have now ( sewerage out let is critical in position and direction
get a compatible cistern that will mount in the same position on the wall
( different brands have different size cisterns that may leave an unpainted section on the wall on fittment)
pans are normally held in place by screws at the base
as I said a plumber has all the gear and knowledge to do the job quickly
Jul 01, 2015 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
Cylpso Toilet Suite D-18156 Slow leak into bowl
You need to replace flapper which is available at where plumbing products are sold,even walmart has them.
Jun 10, 2011 | Kohler Plumbing
Home Logo
1,327 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
