Question about Casio FX9750GII Graphic Calculator
Finding max and min - Casio FX9750GII Graphic Calculator
  • Casio Master
  • 7,993 Answers
After you create a graph, have the calculator draw it. To find the minimum or maximum press SHIFT F5 G-Solv. Use the appropriate tabs MAX, MIN.
Posted on Nov 30, 2012
What is the acceptable max oil clearances on bigends and main bearings on a Cummins 6BT5,9 engine pls. Donr advise AGAIN Buy a Heinz Manual please.
Hi again i found this info on rod & crank clearance 5.9 Cummings .002 to .004 U can always check clearance with plastiguage just to make sure hope this helps GOOD LUCK. only thing i could find was bigend side clearance min .004 max .013in crankshaft end clearance min .004 max.017. ,TRY RINGING CUMMINGS 03 9765 3222 or 03 9360 0800. Good luck....Cummings 6B, 6BT, 6BTA Main Bearing bolts 176 Nm, 130 lb.ft. Con rod 102 Nm, 74 lb.ft. Cylinder head bolts 126 Nm 93 lb.ft ...... Cheers
Nov 19, 2016 | Cars & Trucks
How do I find the max and min value of a sine curve
The maximum value of the sine function is positive one, the minimum value is negative one. Within any limited range the maximum and minimum will fall between the two extremes.
If you have a graphing calculator, the easiest way to to find the maximum and minimum values of a sine curve is to plot it. Some calculators will even automatically find the max and min values. Others you'll have to eyeball it.
If you don't have a graphing calculator, you can calculate the value at a series of points and hone in the max and min values.
If you need further assistance, please reply to this post and specify the make and model of your calculator.
Mar 13, 2012 | Office Equipment & Supplies
I need to find decreasing and increasing intervals and I dont know how to do this on my TI 83
While your TI-83 plus cannot explicitly find increasing or decreasing intervals, it can find the minimum(s) and maximum(s) of a function.
Press the "Y=" button.
Enter the equation in "y=" format into the first open equation.
Press the "GRAPH" key.
If the maximum and minimum of the curve are not shown in the window it has, press ZOOM->0.
Press 2ND->CALC (under the "TRACE" key).
Press 3 if you are trying to find a min, 4 if you're trying to find a max.
It will ask for bounds. Enter a left and right bound by looking at the graph itself and choosing a left bound that is clearly to the left of the min/max, and a right bound clearly to the right of the min/max.
Then it will ask you to guess a value. You can skip this step by pressing ENTER instead of entering a value.
It will calculate the value. To find increasing/decreasing intervals, just know that every interval with a minimum as the left bound and a maximum as the right bound is increasing, and vice versa.
Feb 25, 2011 | Texas Instruments TI-83 Plus Calculator
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
VOLTAGE
These appliances are rated for 208 or 230 volts, so the min/max voltage rating would be min 188 v and max 253 volts. Hope this helps
Mar 22, 2010 | Sanyo SR-4910M Compact Refrigerator
How much gear lube do i put in the crank case of my 93 yz 250?
There is always a dip stick in the crank case to check the oil level. On the dip stick you will find two marks for Min and Max oil levels. The oil should never be more than the Max level and never below the Min level.
Mar 15, 2010 | 2003 Yamaha YZ 250
Need to write a simple (no array allowed) to take three inputs from a user and sort it numerically. Not just provide the MAXNUM. via Javascript
in pCode
Var1 = Input1
Var2 = input2
Var3 = input3
If Var1 > Var2 and Var3
Then Var1 is Max
If Var1 > Var2 and < Var3
then Var3 is Max
Else Var2 is Max
If Var1 is Max and Var 2 > Var3
Then Var1 = Max
Var2 = Mid
Var3 = Min
if Var2 is Max and Var >1 Var3
Then Var2 = Max
Var1 = Mid
Var3 = Min
Repeat the various possibilities and you have got your result without arrays
Oct 05, 2009 | Computers & Internet
Trying to identify chevy engine code and casting numbers
you wont find the horse power with an engine code. you can go to your delar and ask them to explain the code for you. its free.
the max/min HP is up to you think base modle v8 230hp, top from the factory 300hp
you can change that gratly buy going after market.
remeber for 5k you spend you should get 100hp out. min (that includes instalatin and yada yada
May 30, 2009 | 1983 Chevrolet K1500
+12V DC Line voltage reading from PC burn-in test is low
if you really had that drastic of an issue, then the computer would not boot. this is some kind of mis-read.
Jan 13, 2009 | HP Compaq Evo d530 PC Desktop
Movie record
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card HQ 320 x 240 30 fps movie 20 sec. Max movie 6 min. 27 sec. Max movie 12 min.54 sec Max movie SQ 320 x 240 15 fps movie 41 sec. Max movie 12 min. 54 sec Max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Casio FX9750GII Graphic Calculator Logo
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
