Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Hi, I have a yard machine snowblower that starts a little hard but starts. My problem is keeping it running whenever I start to remove the snow it starts to stall out, it will stay running if no load is put on it what can I do?
  • Mark Tripp
    Mark Tripp May 11, 2010
    When running does it surge or pulsate any before you put it under a load?
3 Suggested Answers
  • 8404 Answers
SOURCE: Snowblower- 8HP Yard Machine-Auger(s) won't turn
Check for another sheared shear pin.
Posted on Jan 05, 2010
mindlessforu
  • 7 Answers
Sounds like you broke the belt. The auger housing should be held on by a few bolts between the auger and the engine. Remove the bolts and it should come apart into two pieces. You will most likely find a broken belt there.
Posted on May 23, 2013
My snowblower will only stay on as long as I continue to push the primer. Once I stop it stalls. And the choke is closed.
The bolt that holds the carb bowl on either has an adjustment bolt or it does not. If it does not have this adjustment screw, there is a small hole in the midde of the bolt that needs to be cleaned. The hole is the jet for the carb. I usually use a wire from a price tag and then use carb cleaner with the straw to pressure clean it.
Jan 06, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
Not getting gas
The bulb usually doesn't feel that way, you're thinking of a small 2-cycle machine where the bulb will fill up with fuel and offer resistance when pushed. A primer on a snowblower is merely to get fuel flowing to the carb from the tank, whereas the bulb on 2-cycle items actually purges air from the fuel circuit. If you keep pressing the primer you should see fuel drip from the carb inlet. Btw, if you see where an air filter might be on other motors, a little metal cup looking thing, try removing the bolts and flipping it over so the fuel drips out easier and snow doesn't have the chance to fall into it if it were facing up. Once you see fuel dripping out, provided you ran it dry last season when you put the blower away and the carb isn't gummed up with varnish, it should start on full choke. Give it about 3-5 seconds and move it to half choke. Once it seems to want to run on its own, open the choke completely and you should be warmed up and ready to go. Also always remember to let engines idle a bit to cool down if you've been running them at high rpms.
Nov 11, 2013 | Mtd Yard Machines 24" Two Stage Snow...
Snowblower augers wont turn
Did you check shear pins on shaft for auger
Apr 15, 2013 | Yard Machines Snow Blowers. 22 in....
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
