Question about Sony Computers & Internet
Sony Vaio Pcg-5j2l bad connection screen
The laptop (i believe) fell on the floor while borrowed by friends. Now the screen is F*** up and if I press the bottom part of the screen (where the Sony logo is) changes the looks. Sometimes it disappears and sometimes it appears kind of normal. The image sometimes cust and halves and the bottom part stays on the top and the top part stays on the bottom... What should I do? do you think if I replace the screen it will be better or do you think it is a cable connection problem?
jubag14
  • 89 Answers
SOURCE: Brought LCD Screen to replace cracked one. How to I take apart and replace screen. Any help would be greatly appreciated
there will be two random black spots on the side of your laptop if you pull them off you will find two screws that will be the same on the other side undo all of the screws and pull the plastic of the front of your laptop and the screen will just slide out then follow the wires and you will find a little bit ware you can unplug the wires then do the opisit to putt the screen back in .
please rate my help to you as i am becoming a expert. thank you.
Posted on Apr 21, 2009
wilsonclaude
SOURCE: sony vaio laptop PCG-5J2L montior is black can
Check on line for a bulb to replace the dead one. Cost about 9.00 plus shipping. If you are careful you can do it yourself.
Posted on May 04, 2009
  • 225 Answers
SOURCE: LCD turns white.
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. best regards
Posted on May 17, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Sony Vaio faulty screen?
First, lets make sure that the screen is actually blank or very very dim. Look very closely at the screen and try to see an outline or shadow or anything that might give an indication that the desktop is actually up and running. There is the possiblity that just the backlight is off and the screen is actually working. Try taking a flashlight and shine it at the bottom of the screen and try to illuminate the bottom pointing upwards try to illuminate the screen. If you can see anything on the screen then most likely the inverter has failed and can be replaced by removing the screen bezel, unplugging two connections and replacing the inverter which is secure under the lcd screen itself. The inverter costs approx. 20 bucks.
If you do not see anything, then you need to check the vga port on the laptop. this port allows you to attach an external monitor to the laptop and transfer the image to an external monitor. This will tell us if whether your motherboard has fried out the video card. If you do get a picture on an external monitor, then perhaps the only issue is a failed screen.
Posted on Dec 08, 2009
rohithn
  • 57 Answers
SOURCE: PCG-5J2L won't start up.
Battery is out of charge. Charge the batteries and try.
Posted on Feb 16, 2010
How could I determine the Fn functions on an old VAIO laptop?
You may be able to find out the answer to your question on sony's web site and customer support. All the manuels for your machine should be able to download there.
Sep 09, 2014 | Sony VAIO PCG-5J2L Laptop Charger...
I have a Sony Vaio Model PCG-5J2L. Lately, the fan has been really loud, and the bottom of the laptop has been heating up and it is VERY HOT. Also, the other day, it just shut down by itself while I...
That recall is for VPCF11 and VPCCW2 models. Your issue definitely sounds like a heat problem. Sometimes it can be a buildup of dust, fuzz, carpet etc especially if you use it on a bed or the floor. Check all the vents and make sure they are clear. If the fan is making abnormally loud noises, slight grinding it could be failing. Here is one, retails for about 35 dollars. Make sure you get one with a heatsink, better safe then sorry. It is not too difficult to replace, but if you are not comfortable doing it then it is best to take it to a computer repair store.
Jun 28, 2011 | Sony VAIO PCG-K33 Notebook
Feb 16, 2010 | Computers & Internet
I have a Sony laptop, model PCG-5J2L. DVD Pioneer
1. Try System Restore to rollback ur settings.
2. If it don't helps, u can update the drivers through internet!
tell me if it helps...tc! :)
Jan 05, 2010 | Toshiba Satellite P105-S9722 Notebook
Sony vaio laptop PCG-5J2L montior is black can still see the screen a little bit how to get the screen back????
you pretty much cant.. the light bulb on the actual screen is now dead. If you plug an external monitor to this machine you can still use as a desktop.
Apr 24, 2009 | Sony VAIO PCG-K23 Notebook
Apr 21, 2009 | Sony VAIO VGN-C140G/B Notebook
Notebook will not fully startup
You will have to F8 during boot up and run a system restore I am assuming you are running vista...in the F8 boot screen there is a repair vista.. or something along those lines... The problem is a bad update that needs to be re done most likely Sp1
Jan 23, 2009 | Sony VAIO PCG-K23 Notebook
Page cannot be displayed
make sure that the password is exactly like it should be.
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
PIONEER DVR K17
Hello olejonok,
I ran into this problem while helping a friend with her laptop. Here is the solution:
1) Visit the following webpage: http://esupport.sony.com/perl/swu-download.pl?template=EN&mdl=&upd_id=2031&SMB=YES
2) Download "SOOOTH-01106200-US.EXE"
3) Run the program and follow the instructions, then reboot.
There are several registry filters which, when removed and the system rebooted, re-enable your drive.
Applies to: DVR-K17 VGN-CR220E PCG-5J2L
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
