Question about Frigidaire Washing Machines
Leaking and squealing on spin cycle
The washer is 13 years old, and this is the first issues' we are having with it
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
3 Suggested Answers
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 686 Answers
SOURCE: My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Posted on Apr 06, 2009
Washer has squealing sound and burning rubber odor
Yes, its basically in need of a overhaul, which the parts involved, basket drive/clutch and gearcase are all wearing out, I've seen this happen many times and cause the squeal/spin cycle and then in time to slow then stop spinning altogether.
From the parts diagram it said this model was made in 1998. The only time I have changed these parts on a model this old is when the customer purchased a service contract when it was new and kept paying on the contact year after year, thus the repair was free to them, but most of the time its NOT practical to keep paying on a service contact for up to 10 years unless you have heavy/extreme, daily/many times of day use of the washer, usually for large families living in the same household.
Here's the list of parts I always change for this issue, now some members and techs. could possibly change just the basket drive/clutch assembly or just the clutch alone and it may work for another 6 months or year and a half, but I found when I used to change the parts separately I had to go back to change the other parts within 6-18 months.
Oct 14, 2012 | Frigidaire GLWS1349A Top Load Washer
My 1998 kitchenaid clothes washer, model no. kaws750g squeals for 20 seconds or so at the beginning of the spin cycle. It still gets the water out of the clothes o.k. Could it be a belt or bearings? Thanks
Belt of bearing is a good call; I usually lean toward the belt, especially if it hasn't been replaced in a while. Like on a car, when a belt becomes worn, it develops slick spots that tend to slip before they grab, causing a squeal. It's a common repair and although your washer is 13 years old, that's still pretty young as far as washing machines go.
May 16, 2011 | KitchenAid Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Performa Washer
Hi brawn253
The oil is comming from the transmission. The only way to fix it is to have it replaced. alot of the orlder machiens have this happen and keep working for many years after. as for the squeal its normal. its just the break some of the oils have got in there and the squealing is a resault of that. I wouldnt be to worried about it.
brent
Sep 21, 2008 | Maytag Performa PAV2200
Loud squeal during wash and spin cycles, maytag atlantis washer
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
