Question about Panasonic Home Theater System System
NOISEY FAN I have a panasonic sc-ht990 home theater system and the fan at the rear of unit has become noisy and then f61 code appears. can you help
  • 336 Answers
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Posted on Jan 11, 2009
I have the f61 code on a panasonic surround sound. should both fans spin on power up?
Pretty sure both fans should turn. If the unit senses the fan not turning, it will shut down as you are describing. Try taking the label off of the fan so you can see the bearing, and put a couple drops of oil in there. This sometimes get them to turn freely again.
Dec 28, 2012 | Peerless "Panasonic Sc-Ht990 Home...
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Dec 03, 2012 | Panasonic SC-HT441 Theater System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
NOISY FAN ON PANASONIC SC-HT990
you cant stop it, the fan is going bad, it isnt verry expencive, you should be able to order from there website, i wouldnt hold off verry long, if it is going out, it isnt cooling your reciver correctily, and could cause other damage
Jan 10, 2009 | Panasonic Home Theater System System
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Panasonic Home Theater System System Logo
291 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
