How do i hook up the tv and computer moniter - Televison & Video
Can I hook my tv to my computer an use it as a moniter
If your TV has VGA input socket at its back panel, you can. Otherwise, can't. In most cases CRT based TVs are not compatible with PCs. http://electronicshelponline.blogspot.com/
Sep 16, 2014 | Televison & Video
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Trying to use my tv as a moniter
If you still have the pc monitor pluged and want to use the tv as an exetended desktop
you have to activate the second monitor in the - control panel - Display - settings
Sep 18, 2008 | Computers & Internet
Blinking Screen?
it is monitor problem,it should be EHT problem
Feb 29, 2008 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
