Error code c5003
At power on machine goes into error cose
Please let me know if one of the members can help me to obtain a DIAGRAM TO REPAIR A KONICA MINOLTA C6500 POWER SUPPLY UNIT MODEL NO. LVR-CE 29818 PART NO. A03UM402-01
Even KMBS Tech do not have schematics of that detail on circuit boards
The first code you had was dealing with the middle section of the machine which transports the paper from the right to the left, there is a circuit board that controls the section located under the front cover of that section. the next code you have deals with the scanner under the big glass. either home position sensor is dirty or bad or the drive motor for the scanner is bad or the drive motor board is bad.
Circuit boards about 1000.00 each.
Oct 14, 2015 | Konica Minolta Office Equipment & Supplies
Out of range 90.0khz/60hz
does the dock havae a power button? if so, place laptop on dock while cosed and turn on through the dock.
Feb 06, 2013 | LG W1943SS 19" Monitor
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
Engine warning light comes on and engine goes limp. Missfires and comes back to life. Registered fault code is 77p7-f/inj timing fdbk. Thinking its the timing solonoid. Any ideas
on nissan terrano diesel: had a fault cose 77 and a white smoke, no power. i changed the fuel filter and cleaned the fuel line from the tank to the fuel filter. it solve the problem.
Dec 07, 2011 | Nissan Cars & Trucks
Mitsubishi Triton air bag light "ON" and the error cose B1401 F ABG(1) DR Squib open. May I know how to solve.
Dec 08, 2010 | Mitsubishi Eclipse Spyder Cars & Trucks
Error Code "H" and "4"
The meaning of the H4 code is a fuser warm up failure. This means that the fuser is not coming up to temperature as it should within a certain amount of time. This code comes up occaisionally on the AL series for some reason. The fuser unit in cose you don't know is the part that gets hot and is located right where the paper exits the machine. If the code does NOT reset then the part most common to fail is either the thermal fuse or the heater lamp itself.
It all depends on how often the code comes up. Make sure that the machine is not to "cold" at start up. Install a power filter between to the copier and the power outlet to make sure your not getting any line noise that could cause the flase errors. That is about it.
Jan 11, 2010 | Office Equipment & Supplies
Konicaminolta bizhub pro c6500
its a 24Volt error. It usually means replacing the ADU drive board. no way to cheat or disable it/
Jan 20, 2009 | Office Equipment & Supplies
E73 error or 1021 error code
here is what the error code means
E73: General Hardware Failure: Ethernet port... this error is caused by a problem with the Ethernet port.
and cose 1021 is a ghost code they have no idea from what i have found out
Nov 16, 2008 | Microsoft Xbox 360 Console
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
Needs Access Code
on all these machines it is universally ***1
Nov 20, 2007 | Pitney Bowes 9920 Plain Paper Fax
24 people viewed this question
k24674
