Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Cleaner will not spray when switch is pulled - Bissell 1699 ProHeat Clear View Upright Steam Vacuum
  • Official Brand Answer
  • 315 Answers
Here's a quick link to troubleshooting steps. http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Posted on Dec 05, 2012
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
On and off button doesn't conect
Unplug you unit. Try spraying the switch with electronic spray cleaner you can get a Radio Shack or any auto storeelectricdime_1.jpg. The switch contacts may be dirty. After spraying the switch move it back and forth several times like you on turning it on and off. Then plug it in and see if this helps.
Dec 05, 2010 | Miele Red Star Bagged Canister Vacuum
My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Sep 22, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking apart?
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
Jan 25, 2009 | Kenmore 22812 Bagged Canister Vacuum
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Will not stay running
you have a bad switch.if you have any spray contact cleaner you can spray it in the switch and work the switch a few times and see if it works if not you need to get a new switch.you can get the switch at any vacuum repair shop.if you would like call all-type vacuum and janitorial supply and ask for lisa.she can help you.tell her pete advised you to call.contact cleaner you can get at radio shack.i hope i have been of some help to you.please leave feedback
Jan 12, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell carpet cleaner sprays with every forward motion.
Check the valve at the bottom of the tank to make sure it is opening and closing. If ok, there are some relays, one may be stuck open.
Mar 21, 2008 | Vacuums
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
