Question about Cfm Daikin R410a Split System Air Conditioner
Daikin u4 fault code the wiring is ok on the control think it maybe pcb when looked in outdoor unit the fan fuse blown i have replaced but nothing is there a reset
    Habit-Forming:
  • 31 Answers
If the fuse has blow there is a fault, check all components in outdoor units,
Fans compressors ect a power outage will cause this fault and just replacing the fuse will more than likely cause more damage to the system without checking components first,
To reset power off outdoor then back on this should clear it,
Posted on Dec 24, 2015
    New Friend:
Replaced new wire
Posted on Apr 16, 2013
4 Suggested Answers
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
ar1965
SOURCE: VRV 3 Daikin 2 pipe system. does any one know
no communication between indoor and outdoor units
Posted on Aug 12, 2012
sonicboomele
  • 1557 Answers
SOURCE: Is there a reset button
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Posted on Dec 02, 2010
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Air conditioner installer just installed a used Daikin Split system. it flashes green nothing else happens. According to the error code it says A1. Is it something he has done wrong.
This fault indicates a fault with the fan coil unit PCB and the only course of action is to replace the PCB,
this may have been caused by incorrect wiring and power being switched on, ensure wiring is correct before replacing and powering up
Dec 24, 2015 | Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Daikin FVY125 U4
This is a communication issue between the indoor and outdoor units.
This fault can be caused a issue with the interconnecting wiring such as an induced voltage on the Communication cable or even if a Drain Pump has been installed incorrectly external to the Daikin Unit.
Ensure that the Outdoor unit has power to it and that the Main PCB has a Green Flashing (HAP) LED on it to show that it is powered up.
Jan 15, 2012 | Heating & Cooling
Fault code 049f,this fault shows on hard wired controler connected to high wall unit?
f-049 Check power supply voltage to the outdoor unit is correct (1ph ?220 Vac ±10% or 3ph ?380 Vac ±10%). If OK check fuses, if fuses OK, replace outdoor main PCB
Dec 10, 2010 | Heating & Cooling
May 28, 2010 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
1,334 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
