Question about Viking VGSC306-4B Gas Kitchen Range
Blew fuse I turned on the gas burner and it sparked and I saw the spark from under the control panel. It blew my fuse.
  • 59 Answers
It would appear to be a trapped or shorted wire in the control panel.
Shut the power off and move the control panel, it should be fairly obvious where the short is as it will more than likely be black
Posted on Mar 09, 2009
Our Thermador Pro-Harmony gas range just started to make clicking noises and it will not stop. Nobody turned the stove on. It started clicking on its own. How do we shut it off?
Usually a clicking sound from a gas range is the gas ignitor/igniter sparking to light one of the gas burners
...Check to make sure all functions are turned off. If all are off
could be a defective switch..check to see if you see a spark at any of the gas burners
Sep 09, 2017 | Thermador Kitchen Ranges
My car was running. I bypassed the relay for the A/C compressor to turn on the engine stopped running.Did not start again, checked for fuse, found one blown, Put fuse in, blew that fuse too.
I can't tell what you've done? Where is the fuse located, under the hood--interior fuse box? What is the fuse amp rating and what does it control?
If it cranks good but won't start, make sure the battery has a full charge, have a helper crank it, while you check for spark at the spark plugs, if spark everywhere, check fuel injector pulse.
What about your security system?
Sep 24, 2016 | 2004 Mazda Tribute
Oven will not heat, control panel is eratic, gas burners will not spark
Check fuse box to see if stove is receiving power. Turn one top burn on and hold a lit match to it. if it does not light. Call gas company to see why there is no gas to your stove.
May 15, 2016 | Kitchen Ranges
Fuse in control panel blows when turned on
You have a short somewhere, triplecheck your work. may have a crossed up wiring.
Mar 08, 2015 | Heating & Cooling
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Jen Air gas cook top that wont stop sparking when i turn burner on
make sure there is not a build up of oil or grease
under ignighter
Dec 20, 2013 | Cooktops
1995 ford taurus no gas and or spark
Does the check engine light turn on when you put key to 'run'? It sounds to me like the EEC (electronic engine control) relay is not working. This turns on the computer, which in turn controls the fuel pump relay and spark control. I am unsure of it's location. Possibly under the dash by the passenger kick panel or under the hood. This is what I would consider the most likely cause. It is green in color. The fuel pump relay is in the control box above the radiator and under the plastic panel with the vacuum schematic decal.
Jun 23, 2009 | 1995 Ford Taurus
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Spark igniters on the burners fire continuously
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
103 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
