Question about Clarke Power Products Electronic Reciprocating Saw - CT4008B, by Clarke - Clarke - CT4008B
Carbon brush Wen
Model #950, 1/2" reversible electric drill.
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Will not go forward, but will go reverse
Diagnostic: Poor connection/conduction between carbon brushes and rails.
Solution: Clean carbon brushes and metal rails with solvent. If problem persists you must need to expand the inner carbon brushes' coil spring from the second car.
Jan 09, 2014 | Lionel 11000 Holiday Tradition Express...
Drill sparks
To Short carbon brushes or the electric field is not in balance look if one of the brushes is shorter then replace the electric field but if its on both brushes the same blue and burning smell then the armature has gone , beware of the price and great differences between the kind of hammers.
Aug 10, 2013 | Bosch Drills
Need carbon brushes for makita mod#m601 10mm drill
I could only find a 601D which is a cordless drill with a sealed motor so you can't just replace the brushes and the motor is discontinued.
Mar 31, 2012 | Drills
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
What brosh nedd that drill
http://www.ereplacementparts.com/carbon-brush-set-cb407-p-1518.html
Brushes are CB407. Follow link to order online, or contact your local dealer.
Nov 08, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Replacing carbon brushes of csb 500 re bosch drill
bosch brushes are unique. they have a spring embedded in the carbon so when the length gets too short, the spring lets go and raises the brush above the commutator and the appliance stops. you need to remove the handle partially or the brush covers and unscrew the brush holder(s) two small screws secure the brushes and holder to the appliance.
Oct 13, 2009 | Bosch Drills
Working when posted but dead on arrival.bought on ebay . fuse and lead checked out ok.
where do you live and where did you get the drill from are the voltage ratings the same
May 01, 2009 | Bosch Drills
Clarke Power Products Electronic Reciprocating Saw - CT4008B, by Clarke - Clarke - CT4008B Logo
Top Clarke Power Products Saws Experts
Tom Chichester
ray gallant
Are you a Clarke Power Products Saw Expert? Answer questions, earn points and help others
