Question about ASUS A8Jm Notebook
Asus laptop - screen went blank and will not turn back on
Sounds as though it is turning on but the screen is blank. I have tried reseting it but nothing happens
  • 3 more comments
  • karenferguso Jan 11, 2009
    Possible it may have been dropped not sure. I was playing a game when the screen went blank
  • Anonymous Mar 11, 2009
    Same Problem
  • Anonymous Apr 04, 2009
    I had put a DVD in and the next thing it total sut down. But it was sitting on the bed.
  • Josh Riedy May 11, 2010
    Have you tried hooking it up to an external monitor?
    Has it been dropped it recently? What were you doing when it went blank?
  • mohan rawat Aug 20, 2012
    i have k52n assus laptop its screen has got white blank and not working give the solution
    Problem Solver:
  • 6 Answers
I'm assuming your screen shows nothing at all, even the bios or boot screen as it turns on.
If you can hook it up to an external monitor then your video adapter is working. Try using the vga output on the laptop. If it doesn't show anything use you display select feature. I'm not sure what button it is on your laptop but on mine it is Fn+F8 (look for a button that shows a laptop and/or a rectangle).
If you can see it with an external monitor, you should try to uninstall and reinstall the video adapter. After you reboot the computer hopefully it will work.
However, if it still does not work, you will probably need to reseat the monitor cable. Do this by opening the screen panel. on the back is a flat cable tat plugs in to the LCD. This is usually covered by tape. Carefully remove the tape, unplug the cable and plug the cable back in. Don't forget to replace the tape!
I have fixed two computers in the last two weeks by reseating this cable.
Hope this helps and good luck!
Posted on Jan 11, 2009
  • girlexprss Oct 24, 2010
    I just uad the same problem with mine. I no alot about technology and im 14 haha. Click the button tht says "Num LK Scr LK" Then take out the battery. Blow on thr battery. Then blow where the battery was. This takes any dust and stuff out. Then put the battery back in and click the power button. :) thumbs up for the brainsss
  • Nadine Herring Sep 17, 2013
    Girlexprss I just had this problem this morning on my laptop and went searching for a solution and found this site. I read your solution since it sounded the easiest and tried it, not really expecting it to work. I jot ok me about a minute and a half, I did exactly what you said and it worked perfectly! The screen came right back up and I am good to go. Thank you so much for sharing this,tip, you are a very smart young lady!!!!
Don't know what to tell you, I looked this up today because I was having this issue... I let it rest for about 8 hours and then it worked just fine.. in my case I hadn't dropped it. Noone was home for the last week to do such a thing, but I could hear the windows chime so the comp was definitely booting. Sorta just resolved itself.
Posted on Jun 20, 2012
My asus inbuilt laptop screen goes blank. what is the solution ?
For a start try to remove the battery, wait for some time, then insert the battery. Turn on the notebook. Maybe, it will be useful for you. Meanwhile, maybe you need to reinstall drivers for your notebook which you can try to find here ASUS Notebook Laptop driver download
Mar 26, 2014 | ASUS A8Jm Notebook
My notebook Asus W7J BLANK when is turn on
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your video card is ruined. overheated or dropped maybe? don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may. they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
May 30, 2010 | ASUS W7J Notebook
I have an ASUS Eee PC 900. It was working fine last night. I closed the screen (did not turn off the notebook) and when I woke up this morning and opened had a blank screen. All LED lights are working. ...
One more thing you could try is taking the battery out for a minute or two, because the Eee uses the atom it has a fairly complex onboard power controller that can overclock / underclock the cpu. Sometimes this gets malfunctions and locks the PC up, the quickest way to fix it is to simply pull the battery for a short while and stick it back in. You may well have already tried this, but it'll be the first port of call.
Aug 04, 2009 | ASUS Eee PC 900 PC Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Blank screens/no sound on ds lite
This definatley sounds faulty. Try turning it on again without any games inside. If it turns on okay without a game then it may just be that game you had inserted into it, if this is the case then try a different game to determine whether it is the game or not. If the screen still remains blank then take the DS back to the store where you purchased it and they should replace it free for another one.
Dec 15, 2008 | Nintendo DS Lite Console
Screen
you can press ctrl, alt and the up arrow at the same time. If that doesnt work, right click on your desktop and select graphic properties, then click on display settings on the left, and make sure  you select "0" where it says Rotation on the left panel.
Oct 21, 2008 | ASUS Eee PC 1000H Laptop
Asus Laptop Not Tunring On
Try using an external monitor to see if it's the laptop screen, if it works your screen or backlight is dead.
May 09, 2008 | ASUS Z71A Notebook
ASUS A8Jm Notebook Logo
13,053 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
