Question about Refrigerators
Kitchenaid ice maker full of ice but won't release it
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
peyton32034
  • 410 Answers
SOURCE: Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Posted on Jan 07, 2008
rylee_smith
  • 8619 Answers
SOURCE: Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 02, 2009
bobicehouse
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
  • 103 Answers
SOURCE: AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Posted on Jun 13, 2009
gripfitter
  • 557 Answers
SOURCE: GE side by side CAN17 ice maker...white
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Posted on Oct 27, 2009
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
My EdgeStar Full Size Ice Maker IB650SS won't stop making ice
The eye needs to be re aimed at the target directly across the bin. It has to be clean too.
Mar 29, 2013 | EdgeStar 65 lb. Capacity Full Size Ice...
Kitchen aid icemaker won't dump
Sounds to me that you need parts or as most Whirlpool/Kitchenais Ice Makers their averagte life is 5 years. Call before purchace to confirm but here is what I have for the complete Ice Maker=> 4317943 Ice Maker Assembly
For much more info click here=> Broken Ice Maker Repair
I will be here if you have any other questions, Thanks, Sea Breeze
utube.png You-Tube video "VCUgA5T5ASw&feature=player_embedded#!" placeholder
Sep 18, 2011 | KitchenAid KSCS25FKSS Side by Side...
I have a KitchenAid Side by Side with a stubborn ice maker (modular). It seems to make ice, but it won't complete the full harvest cycle for some reason. I can mess around with it (basically warm it...
Hello Tom,
I see where ya said the water dispenser works good and thats cool! when you do get the i/m to run the ice harvest cycle are the cubes full size? if yes the water supply can be ruled out as a possibility. Besides the water not seeming as cold are other things in the fresh food compartment NOT as cold as they are not as cold as in the past,if yes try removing the grill below the doors and clean the dust from the coil there,if it isn't there its the rear of the ref. by the compressor. One of the first things to be affected when a ref is working hard to keep things cool due to a dusty coil is going to be the icemaker,it will freeze the ice but the internal thermostat inside of the i/m module isn't satisfied its cold enough to start the harvest. When jumping out the T&H what exactly your doing is jumping the t-stat regadrless of the temp. of it ,causing it to run a harvest cycle
I hope this answer helps you,
Gene
Aug 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
The ice maker is not working, it seems to be frozen solid
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
648fs
Feb 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
I bought a ice cream maker from the US unfortuneatly the drive assembley isn't the right fit for my kitchenaid. Do you or can you help me find the right part? Kind regards Robyn Ricketts
Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | KitchenAid KSM150PS Artisan Series Stand...
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
