Question about Lisle Serpentine Belt Tool
Serpentine belt diagram
I need a diagram for a 1998 toyota corolla 1.8 engine. Can you help?
  • 35 Answers
Posted on Apr 18, 2009
  • 1,757 Answers
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1998/make/toyota/model/corolla/1998_toyota_corolla_drive_belt_routing_diagram.htm
Posted on Mar 08, 2010
1998 diagram of serpentine belt Toyota camry
Here is the diagram if you have a 2.2l engine.
Jun 15, 2015 | 1998 Toyota Camry
Need a diagram for a 99 toyota corolla serpentine belt
  • Here is the serpentine diagram for a 1999 Toyota Corolla with and without AC.
  • Thank you for using FixYa
Regards, Tony
Jun 19, 2011 | Toyota Corolla Cars & Trucks
Need a serpentine belt diagram for 2004 Toyota
Sorry for the delayed response.
CLICK
on the following LINK. It has the Serpentine Belt Diagrams you will need.
Thanks.
http://www.2carpros.com/car_repair_information/year/2004/make/toyota/model/corolla/2004_toyota_corolla_drive_belt_routing_diagram.htm
Feb 20, 2010 | 2004 Toyota Corolla
SERPENTINE BELT REPLACEMENT
The Belt Diagram should be on the underside of your hood, however they have a way of disappearing.
If it is not there:
Click on the following free direct Link. It has the correct Serpentine Belt Diagrams for your 2001 Toyota Corolla 1.8L (4-Cylinder) Engine and Engine Options (AC/No AC etc.). Included are Instructional and Directional Diagrams for your use.
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/toyota/model/corolla/2001_toyota_corolla_drive_belt_routing_diagram.htm "HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Feb 14, 2010 | 2001 Toyota Corolla
Need serpentine belt diagram fo r2001 toyota
if the pulley is smoth the belts back rides on that surface if it is ribbed or lined the inside of the belt rides on that surface , you local parts store should have a diagram or dealership .
Aug 27, 2009 | 2001 Toyota Corolla
Hi, I want to remove my worn alternator belt on my Toyota Corolla 1998 1.8L Engine 7AFE (not Serpentine belt). Anyone know correct procedure or how to release the belt tension? Thanks Phil Auckland New...
i use a 1/2 inch leverage bar .there is a hole in the tension pully(usually the top pully) put the end of the bar in the slot and pull. you will have to hold the tension on it with the bar while you remove the belt.
Apr 25, 2009 | 1998 Toyota Corolla
Lisle Serpentine Belt Tool Logo
353 people viewed this question
Top Lisle Hammering Experts
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
