How to run programmable set back on Toyostove Laser 56
Buffalo12980
  • 625 Answers
SOURCE: Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Posted on Nov 10, 2007
  • 3 Answers
SOURCE: toyostove laser 30 has error code EE22
EE22 is a lock out code that keeps you from continuing to try to start the heater. This code usually pops up as the result of a problem with the fuel supply (i.e. no fuel, fuel sys obstruction, clogged filter, water frozen in line, faulty igniter), but could be more serious. To clear the code the easy way, unplug heater for at least 30 minutes. While you are waiting, check your fuel tank to see if you have fuel. Then check filter to make sure the element is not clogged and that there is no air or water (or ice) in the fuel line. If you find a problem with any of these things, correct it before trying to start heater again.
For the rest email me at toyofreehelp@yahoo.com
Posted on Nov 21, 2007
Pnutgllry
  • 57 Answers
SOURCE: toyostove laser 56 H burner coating or burn mat
Here's a link regarding burner mat replacement for a 56 if you have not already figured it out.
http://www.rural-energy.com/publications/catalog/document/318
Posted on Dec 09, 2008
  • 674 Answers
SOURCE: getting code EE 2 on a laser 73
EE 2 usually has to do with the fuel. Does the heater make a loud ticking or thumping sound? That's the sound the fuel pump makes when its not getting any fuel. Check your filter, check the strainer in the fuel sump. Depending on how cold it is any water in the fuel line could be frozen blocking the fuel flow. You might also check the flame rod for soot. It can be cleaned with some steel wool.(nitensheaterservice@embarqmail.com)
Posted on Jan 25, 2010
Testimonial: "by the time that this information was available the problem was solve.dirty injector and flame sensor"
  • 17 Answers
SOURCE: Don't know how to set my toyostove 73 laser?
READ owner's manual
If you don't have one you can get it on-line www.toyotomi.usa
Posted on Apr 14, 2010
I have a toyostove laser 56 that blowback exhaust during windy days. Is there an easy fix? Tom
Three times recently I got the EE 2 error. Each time gunk had built up where the tube goes into the firebox. A delicate scraping with a wire solved the problem. Now, what causes the gunk to build up?
Feb 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
The thermostat setting temperature of my Laser 56 Toyostove will suddenly jump up to a high setting (86) which in turn causes the stove, when not operating, to start up and/or causes the stove, when...
The reason I asked was to see if it is a power supply problem. If the setback had been set on 86 I would suspect you were having power fluctuations causing the heater to go the setback temperature. I will give this some more thought and post something else soon.
Sep 11, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 56 error code CL02
The CL means that it is in the automatic clean cycle. The 02 means that it has 2 minutes left. It will automatically do this at 2:00 AM. If you don't have the clock set it will do it whenever it thinks it's 2:00 AM.
Nov 05, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
The fuel leaks out thruogh the overflow and pump. Laser 56 Toyost
One possibility is that the float is not working properly.
The unit need to be serviced,
Sep 30, 2009 | Rinnai Toyostove Direct Vent Heater:...
How to make auto clean work?
The cleaning feature only cleans the igniter. This can happen automatically by just setting the clock. Clock button in Set position, set current time, button to Normal. The cleaning will happen at 2AM each morning.
Good luck,
Tom Hawkins
May 23, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 56 H burner coating or burn mat
Nov 26, 2008 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
