Question about Panasonic Home Theater System System
NOISY FAN ON PANASONIC SC-HT990
HOW CAN I STOP THIS AS
  • 133 Answers
You cant stop it, the fan is going bad, it isnt verry expencive, you should be able to order from there website, i wouldnt hold off verry long, if it is going out, it isnt cooling your reciver correctily, and could cause other damage
Posted on Jan 11, 2009
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
I have the f61 code on a panasonic surround sound. should both fans spin on power up?
Pretty sure both fans should turn. If the unit senses the fan not turning, it will shut down as you are describing. Try taking the label off of the fan so you can see the bearing, and put a couple drops of oil in there. This sometimes get them to turn freely again.
Dec 28, 2012 | Peerless "Panasonic Sc-Ht990 Home...
Fault code fg1
If it's a panasonic the number are f61 and means the audio amplifier's IC's are damaged and need to be replaced
Feb 02, 2010 | Audio Players & Recorders
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
II have panasonic home theater SC-PTX7, it
Go to the website and enter the model # for Help.http://www2.panasonic.com/consumer-electronics/support/ Good Luck
Aug 30, 2009 | Panasonic SC-PTX7 Home Theater System With...
NOISEY FAN
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Jan 10, 2009 | Panasonic Home Theater System System
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Panasonic SC-HT740
In STOP (no disc)
mode, press STOP button
on the player , and 10
button on the remote
control unit.
Sep 19, 2007 | Panasonic SC-HT740 System
Panasonic Home Theater System System Logo
169 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
