Question about AOpen DVD1648L (750519138717) DVD Drive
2 burners on win2000
I'm running Win2000pro on a 1 gig p111. I had both a cd burner and a dvd burner installed but wanting to back up dvd software I decided to get another dvd burner. I replaced the cd burner making sure to set the new dvd drive as master (same as the cd} and installed it.When I turned my pc back I found both drive letters had disappeared. I checked the cables and everything was tight, so I unplugged the slave. Now the burner works but when plugging in the second burner,I lose both drives again. I've been told it may have something to do with Win2000 and both drives being identical. Any ideas? Would really appreciate some help with this. Thank You
  • david bower Jun 09, 2007
    the hard drive is 120 gig the processor is 1 gig the jumpers were set master at the end of the cable first then slave at end and that didn't help when both drives are plugged in the drive letters disappear right out of the my computer folder and don't show up at all on device manager when i unplug the slave drive the master comes back into both my computer and device manager the drivers are the same for both drives and i've got all my updates from microsoft these were all great suggestions but i had tried them already thx guys
  • 97 Answers
Did you check the jumpers on the drives? If both are on the same cable, use "master" for one and "slave" for the second. Do not let the drives set to "csl" (cable select) as this could cause BIOS or Windows to reaign drive letters. I currectly run 9 machines with three DVD burners in each, six of which have the same model drive. If you have service pack 4 for Win2k you should not have a problem with seeing the drives. Both drives set to "master" or slave on the same cable will cause BIOS to not see either one.
Posted on Jun 09, 2007
  • Kris Wingert Jun 09, 2007
    I forgot to add, a 1 gig hdd will not be even enough room to edit and burn a DVD. It is enough room for a copy machine to make an image and burn it.
    Problem Solver:
  • 8 Answers
Window 2000 could be a probable cauuse.You could try the following. Update windows by installing the latest hot fixes this would most probably solve the problem if the problem is in windows. if the drives show up in device manager. boot you PC in safe mode and uninstall the drivers of both DVD drives.and reboot normally. If this doesnt work let me know your DVD drive make and model.
Posted on Jun 07, 2007
What software do I require to get a external DVR-XD09 USB burner to work with Win2000 SP4?
First you need USB 2,0 software in the pc.
And then you need a burner software.
From here: http://cdburnerxp.se/download
It does even supports your language and system.
Very easy to use.
Hope this was helpfull
Mar 14, 2011 | Pioneer DVRXD09 External Slim Portable USB...
Tip
Problem with WinXPpro, don't recognize PD optical disk
With Win2000 PD-CD LF 1196C works well, but when l install new operating system WinXPpro only works de normal CD but the PD 650Mb optical disk no more work. l will be gratefull because l have too many data in PD disks to backup to DVD.
Thank you for any help on that
on Feb 19, 2008 | Panasonic LF 1196C PD (Rewritable) Burner
New drive for win xp?
No drivers required but use a burner called NERO 8,its great.
Feb 25, 2010 | QPS Que! Combo Drive CD-RW/DVD-ROM Burner
CD/DVD Burner
u can use any CD/DVD burner software, get from google...many are free of cost...
Nero does a good job....older version of Nero are totaly free
Feb 19, 2010 | Toshiba Satellite A355-S6925 Notebook
I am running a core two duo [2.4 ghz] with 2 gigs of ram [two one gig sticks] and was running dual 8800 gts vid cards [now running one] power suply is a 600 w Antec..MB is a p5n32-e Sli Asus, Ok heres the...
CK ALL YOUR DVD CABLES AND BE SURE THEY ARE IN TIGHT, ALSO CK THE MB PLUGS ARE IN TIGHT AND POWER PLUG IN IS DVD PLAYER CORRECTLY. DID YOU INSTALL THE SOFTWARE THAT CAME WITH DVD PLAYER??? IF SO, DELETE IT AND REINSTALL. SOMETIMES THAT IS ALL IT TAKES.
Nov 20, 2009 | ASUS AI Lifestyle P5N32-E SLI...
I just installed an lg cd burner and windows
Did you install the drivers? (The CD that comes with the LG burner?)
Aug 25, 2009 | Computers & Internet
Burner not installed message
James, I have found in the past that many computer manufacturers only install a trial version of some software. One major manufacturer, who shall remain nameless custum built a P.C online that included a CD burner, but I found out later that even though they installed the burner, they provided no burning software. It sounds as though you have no CD burning software installed. First, from the start button, go to control panel, then to add remove software. A list will compile showing all software installed on your machine. If you do not have a CD, or DVD burning program installed and your computer came with no CD's( most today do not) that may contain that program, you will probably have to buy your own at this point. Just to clarify, do you only have a CD burner, or is it a CD burner/ DVD ROM, or do you have a DVD burner. If you have a DVD burner, then you are capable of burning both CD's and DVD's. If you need to purchase burning software I would suggest you do an internet search for Nero, This is the software that I use. It works well in addition to being easy to use.On the Nero site I have in the past purchased their OEM version, the OEM versions are usually available at very good prices. I prefer to purchase software online and have a disc mailed to me as opposed to downloading it online just so that I have a hard copy if I ever need it. If you are limited to burning CD's, just get the CD software. If the device you have installed in your computer is a DVD burner, then purchase the DVD software and you can burn on both formats.
Sep 27, 2008 | Microsoft Windows Vista Ultimate Edition
LG Cd Writer driver need
go to  lg domain  site  there you will get the os compatible then only
if not try pahzeddl.com ddlspot.com   search u will get
Nov 07, 2007 | LG GMA-4020B Super-Multi...
AOpen DVD1648L (750519138717) DVD Drive Logo
37 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
