SOURCE: MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
Something may be stuck in the belt or inside of the machine.
The following may help.
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
SOURCE: Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
SOURCE: I have a Maytag washer model # mav 5057aww and it
there is no adjustment most of that paticular machine had 5 to 10 yr part warranty on transmisson call your local maytag store
SOURCE: Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
SOURCE: Maytag MAV 9600 grinding noise/no agitation. Tub
I had a problem similar to this. There was a bobbie (?) pin stuck in the pump. Google how to take the front off and then disassemble the pump. (It will be on the bottom right side in the front of the machine). Pretty simple. Took about an hour and a half.
