How to install corrector cartridge - Office Equipment & Supplies
  • 3,594 Answers
Make? Model?
Posted on Nov 30, 2012
How to retrieve item dropped inside Celestron C8 telescope
Very Important! Mark the corrector with tape between the corrector and the side so you can put it back in the exact same place. Do NOT tilt the scope down or the eyepiece will slam into the secondary or the corrector plate, Remove the screws holding the corrector. A strong suction cup can help lift it out (will make a mark to be cleaned later.
Gently tilt the scope down to remove the eyepiece. Re assemble and you will probably have to collumate.
Oct 14, 2014 | Celestron C8-S 11025XLT (480 x 203mm)...
Why won't the new ink cartridge/corrector ribbon I bought, work?
there is a rubber bumper on the print solenoid the goes soft it needs replaced see a repair shop
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
How to install corrector tape into AX325. Seems to be in place and black ribbon seems to be in place but corrector tape does not work
Be sure the correction tape is thru both guides and that the dull side faces the paper. Go to brother.com click on support you will find a manual there.
DickyO
Mar 27, 2012 | Office Equipment & Supplies
Lube stain on Secondary mirror on CPC 1100
Probably lubricant out-gassing which can collect than drip. Your choices are to contact Celestron service or do it yourself. DON"T PANIC! It is not that hard if you are brave.
1. Use a piece of masking tape on the corrector to the side of the housing.slice it carefully where they meet. This will insure correct alignment with the primary when you put it back together. (Correctors are sorted then oriented to,(as the name says) correct the primary.
2. Remove the corrector plate. Mark any shim locations with a marker on the outside of the corrector plate (remove after re-installation)
3. Make a solution of 50% distilled water and 50% isopropyl alcohol. (97% pure or better- I use 99% pure alcohol) 1 drop of dish detergent may need to be added,depends on the stain.
4. Rinse the secondary until grease is gone. Do not rub mixture on mirror, just keep rinsing.
5. Rinse with pure distilled water,gently stand corrector up to dry.
6. Assemble the scope. Use the same water/alcohol mixture to clean up the outside of the corrector. Dampen cotton balls and wipe with VERY light pressure.Wipe once, throw the cotton ball out and use a fresh one. Do not make the cotton balls too wet, you don't want moisture to get under the corrector.
7. If the stain is really tough, acetone may be used without damage to the mirror surface.
8. Use surgical gloves to avoid fingerprints.
9. Lots of towels at work area in case the corrector slips out of your grip.
10. If you put it together correctly, minimum collimation will be required.
There have been a number of these problems cropping up lately, I think Synta is using inferior grease now.If you are really brave, clean the old grease
off and add one drop of lithium grease. Run the primary through focus range a few times to distribute.
If you do this, you can later flock the inside of your scope to increase contrast.
Dec 29, 2011 | Celestron CPC 1100 GPS (XLT) (70 x 280mm)...
How do I install Ko Rec Type corrector ribbon on a Wheelwriter 1000?
The correction cassette snaps on to the bottom of the ribbon cartridge and they both go in together. You can go to (best to copy and paste this)
http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1258479940253
DickyO
Dec 11, 2010 | Lexmark Wheelwriter 1000 Typewriter
How to change the corrector tape?
Go to brother.com, click on support you will find a manual there.
DickyO
Jun 04, 2010 | Brother GX-6750 Typewriter
Make the corrector plate meade 203mm
Meade will NOT sell you a corrector plate. They will want the scope back. The corrector plate must be matched optically with the mirror. It is VERY expensive to make this repair, and may not be economical to do. Call Meade:
http://www.meade.com/support/index.html
Oct 17, 2009 | Meade Optics
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
How to remove the corrector lens of a Nexstar 4
I would not try to remove the corrector plate-- the manual states to return the scope to Celestron if the inside of the corrector needs cleaning.
If removed the corrector has to be replaced in the EXACT position it was in before you took it apart-- the alignment between the front corrector plate and the rear mirror and the secondary mirror was done on an optical bench at the factory.
I doubt that will you notice or be able to see the small stain while you are observing--
Mar 15, 2009 | Celestron NexStar 4 GT (240 x 102mm)...
Smith Corona PWP90 corrector cartridge problem
sounds like the corr tape doesn't have the proper tension on it. turn wheel on corr tape cartridge, or if there isn't a wheel, some don't, there is a little lever to the left and under the left side where the cart. fits down. push this until the arm on the right side moves to the left
Jan 02, 2009 | Smith Corona Wordsmith 200 Typewriter
14 people viewed this question
k24674
jasbo
jasbo
