Question about Dell Ethernet Card Network Adapter
Identify correct network card for dell xps 420
I have a Dell XPS 420. I need to know what kind of network card to buy. Is there a recommended card to buy? The card I pulled out says Netgear on it. I am not sure what info you need to answer correctly.
    Sergeant:
  • 236 Answers
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Posted on Dec 19, 2012
  • 155 Answers
SOURCE: Do I have an ethernet card?
Yes, Intel Pro/1000 is gigabit ethernet, which will do 100Mbps and 10Mbps too.
This will be compatable with your broadband requirements.
Posted on Feb 21, 2009
beeveez
  • 167 Answers
SOURCE: Error:Starting Network 363: can't open/etc/dhcpc/dhcpcd-eth0.info
Have you tried to reload the software for the Network Adapter? If not! Have it first.
Posted on Mar 09, 2009
driveallnigh
  • 89 Answers
SOURCE: Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Posted on Apr 17, 2009
joelr2005
  • 464 Answers
SOURCE: i need network/internet card for dell optiplex
you can purchase a pci Network interface card
here is one:
http://accessories.us.dell.com/sna/products/Networking_Enterprise_Class/productdetail.aspx?c=us&l=en&cs=04&sku=A1141863
Posted on Jan 10, 2010
rommelalilin
  • 2178 Answers
SOURCE: I have an old Dimension 8200 Dell desktop
Staples.
Posted on Nov 15, 2010
My XPS 420 desk top won't accept my SD card
The format on the sd card may be faulty constituting a format before it will except it, back info on sd card in a safe location and format.
Sep 10, 2014 | Dell XPS 420 PC Desktop
I have a web cam in my monitor. It won't work, the computer (XPS 420) won't even recognize it. How do I get it?
Kindly check if it's still detected on Device Manager. If the driver has been removed, there should be a question mark right beside the name of the device. Try reinstalling the driver, support.dell.com. To simplify your search, type in te service tag number of your computer. (It's a 7 alpha numeric identifier code which can be found on the dell sticker)
Sep 01, 2013 | Dell XPS 420 PC Desktop
Xps 420 start up problems error codes 1 and 3
Dean Fowler,
The 1-3 error code that you are saying that your computer is making represents a Video Memory Test failure. Try reseatting the video card in your computer or replace the video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 29, 2013 | Dell XPS 420 Desktop Computer
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
Connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Feb 06, 2012 | Dell XPS 420 PC Desktop
My Dell XPS 420 restarts itself whenever i play games on it
You might need a new Graphics card and a 400 w power supply. also, try cleaning it (the fans and HS's
May 13, 2010 | Dell XPS 420 DESKTOP - Intel?® CoreTM2...
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Dell Ethernet Card Network Adapter Logo
364 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
