Question about StarTech.com (PCI420USB) (DHPCI420USB) Serial Adapter
Can' load driver
I have the drivers on a su pplied cd. can't get them to load/
  • Warren Hanson Jun 06, 2007
    I have a pentium 4 1.2 running XP pro I put the PCI usb card into the slot. It seems that the card is not being recognized. Yet when I look for it in the system, there it is. I tried to load the driver and when the system restarts, no card.
    President:
  • 2,961 Answers
When you say you look for the card in the system and it shows you must have a windows generic driver, as you say you cannot get the driver to work, so uninstall the card and remove from pci slot and start again. if you are instructed to fit the card do so, but when the window in your taskbar pops up, it should say hardware, and then install the driver automatically, or a pop up will ask for the driver. if this is the case do not allow it to install the driver automaticcaly, select manual install instaed and in the next window there is an option to make windows look for the driver on your cd drive, tick this and then it should look in the folder on the cd for the driver, click next and the correct driver wil be installed, if it cannot find it, you may have to run the cd as a setup for the driver software and then the card will be recognised that way, it depends on the card instructions as to whether it is driver or hardware to be installed first.
Posted on Jun 06, 2007
    Genius:
  • 2,985 Answers
Say more about the system that your are loading into?
SOURCE:
Nvidia 7100 GS
Maybe you are loading the wrong driver ?
Try automating it by using Driverpacks Solution, it's free, and it automatically updates all your drivers.
Grab the DVD via torrent here :
http://drp.su/
And run it :)
Apr 19, 2014 | Computers & Internet
Im want m981g 5.0a motherbord driver cd im lost my driver cd
Download Driver's Pack Solutions 2012. Here's the link: drp.su/download.htm
hope this will help :-)
Jan 19, 2012 | Computers & Internet
Me pide que instale el driver y esa camara no traia driver..
Hola.
Por favor mire si la camara es compatible con su sistema operativo. Una camara puede ser instalada automaticamente en vista y no ser compatible con XP.
Si la camara es compatible mire si los controladores son disponible en el sito de la camera (por ejemplo si la camera es Logitech mire logitech.com).
Alguna camara tiene un cd pequenito escuendido adentro del carton de la caja.
Intente llamar el revendedor si todavia no se soluciona. Si la camera es compatible con su sistema tiene que ser instalada automaticamente, o debe de aver el CD con el software.
Suerte.
Ginko
Apr 25, 2011 | Computers & Internet
No puedo inprimir nada
Hola, necesita decirnos el modelo y la marca de su impresora.
Envienos otra pregunta , incluyendo el modelo y marca de su impresora, y la palabra Driver, que sinifica controlador.
Por ejemplo si la impresora es Canon Pixma MP310 , titule la nueva pregunta como : " Driver - Canon Pixma MP310 " recivira un enlace al sitio web de donde descargar el software para su impresora.
Muchas gracias.
Mar 25, 2009 | Canon Office Equipment & Supplies
Error no nvram found(lexmark t642)
Usted tiene que instalar de nuevo su impresora.
Si usted hace que su CD de instalación haga este:
No instale el viejo software - van para Comenzar> el Panel de Instrumentos> instala y no instala> voluta abajo hasta que usted encuentre su impresora si es todavía ther y chasquido en no instalan.
Apage la máquina y desenchúfelo
Apage todos sus programas de correr incluso su control de virus, usando los iconos en el derecho inferior.
Reanude su computadora.
Si usted no tiene el CD usted puede cargar abajo al conductor en el sitio de fabricantes. Esto será www. (la marca de su impresora) .com o usted puede google para encontrar el sitio correcto. Una vez allí van a conductores y telecargas y búsqueda para su modelo de impresora y op sys. Asegúrese que usted elige al conductor correcto. Una vez que usted lo ha localizado, apaga todos los programas de correr, lo descarga y LO SALVA a su escritorio. entonces chasquido en ello para instalar.
Siga todas las direcciones encima justo como si usted tenía el CD.
Buena suerte.
Por favor avíseme si este trabaja y tasar mi solución. Gracias.
_______________________________________________
You need to reinstall your printer.
If you have your installation CD do this:
Uninstall the old software -go to Start>Control Panel>install and uninstall>scroll down until you find your printer if it is still ther and click on uninstall.
Turn off the machine and unplug it
Turn off all your running programs including your virus control, using the icons on the lower right .
Restart your computer.
If you do not have the CD you can down load the driver at the manufacturers site. It will be www.(brand of your printer).com or you can google to find the correct site. Once there go to drivers and downloads and search for your printer model and op sys . Make sure that you choose the correct driver. Once you have located it, turn off all running programs, download it and SAVE it to your desktop. then click on it to install.
Follow all directions above just as if you had the CD.
Good Luck.
Please let me know if this works and rate my solution. Thank You.
Aug 21, 2008 | Lexmark T642 Laser Printer
Necesito ayuda .......
tengo una camara web marca cap y no tengo elo cd con el driver el codigo de la cam 49152-DM
Jul 23, 2008 | Computers & Internet
Driver for Audio device on high defination audio bus, Intel motherboard
audio driver for high deffination
the mother board is foxconn 945 - cmx series
Jul 17, 2008 | Intel D102GGC2 Motherboard
Toshiba satellite 200 wont work
Hi westgir168, do you have the restore CD or CD's that came with the notebook? If yes than load CD 1 into you're cd-rom & restart the notebook. It should load the CD. Follow the on screen instrustions to reinstall windows & drivers.
If no, you need to check you're notebook. Somewhere you will find a sticker for microsoft.(if not on the notebook it will be on one of the small books like a user manual or on another docmunt).
It will list the version name of windows that is installed on the notebook & show the CD-key for windows. Borrow a friends windows CD that is named the same as notebooks. (Ex. Windows Home or Window Pro edition).
Use their CD to re-install windows, than use your CD-key during the install. Find your driver software from Toshiba at this link.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
(That IPod might have had a virus on it).
Luck!
Mike
Apr 06, 2008 | Toshiba Satellite L25-S119 Notebook
Hardware drivers
Theses sites will get your computer back up and going again.
If you would want the Driver CD....... Call Toshiba Support line
or..... can down load what ya need from the sites below and put on a cd your self for safe keep.
Related searches: Good Luck ..Please dont for get to Vote.Thank you
Dec 07, 2007 | Toshiba Satellite A105 Notebook
StarTech.com (PCI420USB) (DHPCI420USB) Serial Adapter Logo
932 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
