Question about Blaupunkt Car Audio & Video
Have a Florida RD 168 Model Car Stereo Unit w/CD player....the On/Off Button (Glowing Blue Button on left side of unit) has a bad contact/connection and needs to pushed multiple times to turn on unit (finding and pushing a limited sweet spot). Any suggestions on what could be the problem and how I might fix this annoying glitch on an otherwise good unit?
  • Boz Nov 30, 2012
    There is a "brand new" faceplate on Ebay right nowhttp://www.ebay.com/itm/Blaupunkt-Florid... and I looked at the schematics for the faceplate and looks like it might be a microswitch instead of the rotary encoder.
  • Ted Donahue Nov 30, 2012
    thanks for the heads up.....price seems to be a bit high for this item given the fact that the unit is almost 10 years old. I will see if they will take less $$$ or I will try to fix the loose connection in current faceplate. thanks again....really appreciate it.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
I wasn't able to access a parts explosion for the stereo but more than likely the stereo either uses a rotary encoder/pushbutton combo or two separate switches. The push button has probably worn out and requires replacement. Face plates are not that complicated when taken apart and you can try to wedge something in between the knob and the switch to give you more travel when pushing the power button, which might help the issue.
Posted on Nov 30, 2012
  • 1 more comment
    thanks for the input.....will check this out to see if it just might work....don't know where to find a replacement button for this unit.....any ideas? Thanks kindly.
  • Boz Nov 30, 2012
    I don't have any suppliers that carry Blaupunkt parts in the US, you would need to go overseas or try to find one on Ebay for parts. If it's not a proprietary part you may be able to match the part up on Mouser Electronics or another distributor.
    many thanks....
  • 12 Answers
SOURCE: Factory "single" CD player won't eject CD
hi there should be a reset button on the front of the unit it mite be as small as a pin they usually are.another option is to take the unit out and pull the power lead out the back this will reset the unit and eject the cd.make sure before hand you check you user manual for a code for the unit just in case you have to re enter the code hope this helps...
Posted on May 21, 2009
fkuk
  • 311 Answers
SOURCE: wiring a kenwood stereo into a fiat punto
i think that the red wire is the acc wire but im not 100% on that because you havenot witten what model the radio is
anyways if it is the acc wire then connect that to a 12volt supply and see if it turns on all other wires must be connected though ecept for the blue wire which i think is the remote wire for a amplifier
Posted on Jan 01, 2010
  • 171 Answers
SOURCE: I have a Daimler-Chrysler CD player that I would
Usually the universal colors are Yellow---battery; red---accessories
Orange –illumination; black –negative; then the speaker’s white-white/blk;
Purple-pur/blk; green-grn/blk and gray – gry/blk. Blue and wht/blue are power antenna or amp turns on. That is all you need to know
Posted on Jan 03, 2010
iadame
  • 676 Answers
SOURCE: KENWOOD KDC 1020s speakers not working
You will need to hool up the blue and white wire will need to be connected to the amp turn on in the vehicle. Hopefully you are using an installation harness to make your job easier. The vehicle has a small amplifier in it. it does need to be turned on when you turn on the stereo.
Posted on Jan 05, 2010
Testimonial: "Very quick respone"
SOURCE: need radio manual for kia rio 2005 cvvt
DISCONECT BATTERY FOR A WHILE THEN SHOULD RESET.
THEN PUT THE CODE IN WHICH I GOT FROM .
CAR-RADIO-UNLOCKING.CO.UK CHEAP ASWELL .JUST NEED TO GET NUMBERS OFF BACK OF HEAD UNIT .HOPE THIS HELPS
Posted on Jan 12, 2010
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
I disconnected my car battery now my sevilla 168 will not turn on please help
GPS systems are standard features in many new vehicle . A GPS system communicates with satellites to provide directions through unfamiliar locations. However, older vehicles don't come with GPS, and many drivers purchase aftermarket systems for their vehicles. Installing a GPS system in your vehicle can increase its value and help make traveling a much more enjoyable experience.
Instructions And Materials Needed Below.
  • Plastic putty knife,Flat and Phillips screwdriver set,Wrench set,GPS system
  1. Slip the edge of a plastic putty knife under the edge of the radio face and lift the plastic housing off. Most aftermarket GPS systems incorporate a radio or CD player to replace the old stereo.
  2. Loosen the bolts on the left and right side of the stereo and pull it gently out of the dashboard. Unplug the connections at the back of the stereo and unscrew the mounting bracket on each side.
  3. Connect the mounting bracket from the stereo to the sides of the GPS system. If you've purchased the correct GPS unit for the make and model of your vehicle, the bracket will attach with just a screwdriver.
  4. Plug the wires into the back of the GPS system and slide the unit back into the dashboard. The ports on the back of the unit will be color-coded to correspond with the proper wire plugs, so there is no confusion when connecting the unit.
  5. Secure the GPS unit by inserting the bolts back into the bracket and tightening them with the wrench. Replace the plastic cover over the face of the unit and press it down until the plastic holders click into place. Turn the vehicle on and follow the instructions on the screen to program your new GPS system.
Good Luck.
Dec 07, 2010 | Blaupunkt GPS
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Unit no power on, only ¨beep¨ the power button.
Either the power supply is bad or there is a bad fuse.
Oct 23, 2009 | Jensen VM9410 Car DVD Player
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Mar 04, 2009 | 1999 Ford Escort
Avh-p5700 pioneer
My first suggestion is to not purchase "used" electronics from eBay. I bought the same kind of unit from eBay... and mine is broken too. I got a cell phone, car stereo, and a remote.. they were all not working properly when I received them.
Did you try the restart button. It is a small, pin size button on the right-side of the unit near the 4-way select buttons. My player wouldn't eject a cd either, and when I pushed the restart button with a pin, the cd ejected and the unit was ok for playing cds... that's about it
May 04, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Mitac Mio 168 sound - adapter 2.5 to 3.5 mm jack
I believe there is something wrong, its a normal stereo socket.
I use differend 3.5 to 2.5 adapter (standard, from the shelf)without any problem to connect an FM Stereo-Transmitter.
The best solution to connect your car radio, its wireless.
regards JK
Dec 09, 2007 | Mitac Mio 168 Pocket PC
Car Audio & Video Logo
167 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
