Question about Craftsman Garden
Garden Tractor creeps along and no power to pull Cyclone Rake!
Mowing Mom here--my Craftsman GT with Kohler engine starts fine but just doesn't have the power to move very fast and can't pull my Cyclone Rake anymore. Starts --a little more choke needed now than before to start. But just creeps along. Hubs just replaced the mower belt--happened after that. Also notice a screeching sound every now and again (kind of like when a belt is going on a car). Don't know if that is related or not. Appreciate any direction on what to check--hubs is handy, but mower is my baby.
  • Craftsman Master
  • 8,404 Answers
I love my Cyclone Rake. Double check your main drive belt to make sure it is in good condition AND, if you replaced it recently, that it is properly routed. I replaced the belt on my Genuine Troy and I did it wrong and only knew it AFTER I had destroyed the belt. Hope you can ID your trouble quickly.
Posted on Nov 30, 2012
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
panilling9
  • 284 Answers
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Posted on Jun 07, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 1584 Answers
SOURCE: 26hp kohler garden tractor won't start, Has spark,
Have you checked for a good spark from plug, if in doubt replace spark plug.
Posted on Jan 26, 2010
Turns off during mowing
It sound like its over heating try checking your thermostat
Dec 15, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Uneven mowing
make sure the belt sits level there is adjustments for each side
Aug 20, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
When you engage the mower the tractor looses power and just creeps along. We have replaced the battery, fuel filter, air filter, and blades. Nothing seems to work. Any ideas?
Fuel mixture is wrong - your carb needs cleaning - specifically the jet.
At idle - it works fine - but under load it bogs down because the demand for fuel is increased... but not delivered.
Thanks!
Jun 15, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
