Question about Toshiba Satellite A135-S2386 Notebook
My screen needs brightening - nothing I've tried has worked
I tried using the "power options", both on the battery icon and in the control panel - nothing. I also tried pressing the Fn and F7 key - also nothing. Any other ideas?
  • Toshiba Master
  • 7,627 Answers
Have you updated a Graphic driver?
Posted on Nov 29, 2012
  • 1 more comment
  • Rosanne Moore
    Rosanne Moore Nov 29, 2012
    Sorry to be stupid, but not that I know of. Should I? If so, how is it done? Thanks in advance.
  • max carson
    max carson Nov 29, 2012
    Are your windows updates updated? Are your Toshiba updates installed? I don't know your OS 32 or 64bit?
  • Rosanne Moore
    actually, there are some updates that need to be installed. I'll check for other updates.
lumidee
  • 15 Answers
SOURCE: Solution
replace the keyboard
Posted on May 28, 2008
SOURCE: fn keys not working toshiba A200
T HotKey failed
Posted on Apr 11, 2009
the_fire
  • 432 Answers
SOURCE: The 'Fn' key doesn't seem to work anymore. Need to brighhten my screen
go into the bios ( F2 or Delete or which ever key it states when the computer starts up to get into the bios )
Ensure that the FN key is not disabled in the bios, if it is re enable it and try it again.
Otherwise I would call toshiba and see if the warranty covers it still if not you may have to get them to repair it or call around laptop shops to get them to look at it - may require to replace the keyboard .
Posted on May 27, 2009
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
igor106
  • 277 Answers
SOURCE: Fn F6 and F7 stopped
First, try to test the functionality of the Fn key by using it to alter another setting on your laptop. If it doesn't, you'll need to go to BIOS and enable the Keyboard Function option (or alike, depending on your BIOS version).
If the Fn key does work, then try to see if F6 and F7 function at all. For example, if you're using Firefox, the F6 key should highlight the entire URL of the website you're visiting. F7 brings up a "Caret Browsing"dialog box. If both keys function well, then you may want to reinstall the drivers of your graphics card. If nothing happens after the update, and if you use Vista, then go to Start, and right-click on the Computer label. From the popup menu select Manage, and in the new window go to the last listing, where you'll find a sub-entry labeled Services. Click on it, and from the list on the right, look for a service that's called Keyboard shortcuts or alike (sorry I don't remember exactly how it's labeled as I dont use Vista). Double-click this Keyboard service, and from the new windows see if it's started, and if it's set to Automatic run each time Windows loads. Then restart Windows and hopefully your LCD will dimm/brighten.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Posted on Jan 23, 2011
Screen won't brighten
On Battery or Plugged in? You didn't post the OS you are using, Open the Power Options, set to High Performance, open Change Plan settings, Adjust to your preference, Change Advanced settings to your preference.
Mar 11, 2013 | Computers & Internet
Fujitsu lifebook A series brightness control not working.
Right Click Power icon in Tray Notification Area, click on Power Options, The power option you chose, to the right, open Change Plan Settings, Adjust Plan Brightness.
Nov 22, 2012 | Computers & Internet
Help. I can't adjust the brightness on toshiba satellite C870. It's new to me and hard to use in different rooms. fn/f2/fn/f3 does not work.
First are you using battery power, does it brighten when plugged in ? Go to the Taskbar Notifications Area look for the battery/power Icon right click choose Power Options click openPower Options, you will fid your Power Options located here, Your laptop probaly is defaulted to Power Savings, I use High Preformance, change them to your preferences, REMEMBER, There is a reason the laptop dims on battery, to save energy and extend battery between charges.
Nov 06, 2012 | Toshiba Satellite C870-ST2N03 : Laptop...
Dell Precision M6300 turns on and then nothing happens.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Dell Precision M6300 Notebook
ACPI\PNP0800\4&15ECBBED&0
Unplug power adapter from computer, remove main battery, now press and hold power for 2 minutes in an attempt to reset.
May 02, 2012 | Dell XPS M1330 Notebook
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
ASUS U50F webcam not working for months. I have looked through tons of forums, I've tried contacting the *nonexistent* support on ASUS' website and they never even helped me. I got this notebook...
Most likely you have another chat program using the camera. Right click on the icons in the systray next to the clock and exit programs. After exiting each program, try the camera again. The last program you exit before the camera is the one causing the problem. Restart the computer and right click on that program and try and set it to not start when the Windows starts.
Jim
May 12, 2011 | ASUS U50F Notebook
Compaq Presario R 4000 to dark when on battery only.
The R4000, or at least mine will appear to be brighter when on battery also. If you press the function key and then the f8 key it will brighten the screen.
Feb 24, 2009 | HP Compaq Presario R4000 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
