Question about HP Hewlett Packard Designjet 500 42" Wide Format Printer Plotter Model C7770b
Hp design jet 500 error code 5613? - HP Hewlett Packard Designjet 500 42" Wide Format Printer Plotter Model C7770b
    Problem Solver:
  • 10 Answers
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Posted on Jan 02, 2013
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
Hp design jet t790 error code 2.0.10
Wrong error code, Pl check once again
Dec 01, 2014 | HP Office Equipment & Supplies
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Aug 13, 2014 | Office Equipment & Supplies
My design jet 500 says I am out of ink, when in fact 3 of 4 are full, why does this happen and is there a way around this issue
hi, for this issue to resolve power off the printer , remove all cartridges check the contacts in the ink station assy,try cleaning with a lint free cloth,try replacing cartridge and if the issue still persists conduct service test for ink station assy if the result is negative replace the ink station assembly. You could also get repetitive Ink Cartridge Error messages if the Ink Cartridge is leaking.
Venkateshwar, hp technologist, contact:+91 0086427911
Sep 21, 2011 | HP DesignJet 500 InkJet Printer
I have an HP design jet 70 showing error code 2210 any help would be appreciated.
22:10 Ink Supply Station failure.
Get the Ink Supply Station replaced.
Get a tech to do the work. You will not want to do the work yourself.
May 05, 2011 | HP Designjet 70 InkJet Printer
Our design jet 500 is showing a system error of 86.01
>Check carriage axes usage reached 100%? check carriage warn out position, feel old? replace it.
> Check carriage assm play..feel over play replace carriage bushings & lubricate it.
> Check carriage stuck in service station?, find out the reason shoot the problem.
Jan 14, 2011 | HP DesignJet 500 InkJet Printer
We have a HP Design Jet 500 We turned it on and this is the error code. System Error 21:10 0X3010002 Task Temech file sequence.c line 758
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | HP Design Jet 4020 InkJet Plotter Printer
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
HP Hewlett Packard Designjet 500 42" Wide Format Printer Plotter Model C7770b Logo
307 people viewed this question
Seeker5211
Seeker5211
