Question about Hunter Ceiling Fan Light Switch Control
My fan light stopped working. Its a hunter with a 3 way wall switch for light, fan, reverse and power. I wanted to see if power was getting to the light so I tested the wiring and it was showing power. I decided to change the light receptacle since power was there yet no light. To my surprise whenever I attach a new light receptacle from 60w down to calabra fixture the power to the light stops. Is there a shutoff somewhere in the fan. If I start the fan and shut off the power to the light it resets and then shows a live wire until I add any fixtures? Any ideas what is wrong???
4 Suggested Answers
  • 3 Answers
SOURCE: I have a 52
u have a short in that socket. don't put other bulb in there because you might blow the whole circuit if u keep doing that.
Posted on Mar 10, 2009
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
SOURCE: Wiring Hunter ceiling fan into old house. My house
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Posted on Mar 20, 2012
Hunter Ceiling fan remote will only work for the light. It will not work for the fan. I have paired it.
  • Disconnect power at the source
  • Remove batteries from the remote and press buttons to be sure none are stuck. Reinstall batteries
  • Reconnect power and test operation
If you are using wall switches in addition to the remote, decide how you want to control fan and lights and don't confuse things.
Apr 04, 2017 | Hunter Dryers
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Both the fan and the light stop working. What are the first things to try?
Good way of asking for help!-- Thank you!
First make sure the circuit is not tripped at the Circuit Breaker--
(Are other lights on the same circuit still working OK?)
You will need to verify which breaker controls the voltage to this fan--
and you will need to turn the breaker OFF, while dismantling the fixtures.
Can you communicate with someone at the Breaker Box, while you work safely?
Have them turn the circuit on when you are safe and ready -- and reading voltage, etc.
Next-- Do you have a dimmer switch, (or just a wall switch) on the wall?
Do you know if the power is supplied to the ceiling, thru that wall switch?
If so, check to see if the dimmer or the switch has power coming in and out at the wall, and heading up the ceiling supply wire.
If the power is supplied at the ceiling, then you are going to have to get a safe ladder, and remember Ladder safety rules!
The tough part, is getting the heavy fan and light assembly safely down, where you can make some voltage readings at the supply circuit wires at the ceiling--
Maybe you have found a loose wire nut by now?
Or maybe a defective dimmer or wall switch?
Or what are you observing at the junction box, and the fan motor now?
Tell us more-- and we'll see if we can help yo to the next step.
Mack B,
Jan 18, 2011 | Hunter Ceiling Fan Control Switch
I have a Hunter ceiling fan with light kit. The controls for the fan and light are on the wall. It is a Hunter dimmer and 3 speed control switch. The fan works fine and the lights do not come on. I have...
Usually you have to press the light switch 3 times and hold to get dim effect adjustments, it is often radio transmitted in some newer models, if the pull switch is bad replace it anyways it could be dangerous if let alone!
Aug 23, 2009 | Hunter (25417) Ceiling Fan
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
126 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
