Question about Brother MFC Series MFC-8710dw MFC / All-In-One Monochrome Wireless
MY fax is now saying POOR LINE CONDITION/ OUT OF MEMORY ALL THIS STRATED AT 9:23AM CAN SOME ONE HELP ME NOW
PLEASE HELP IT SAIDS I HAVE POOR LINE SO WHAT DO I DO. WHAT ABOUT THE MEMORY I DO I CHECK FOR THAT WERE IS THAT ON THE MACHINE. PLEASE SOMEONE HELP.
  • 105 Answers
SOURCE: OUT OF MEMORY
Just because you can hear fine when you call the same number and talk to the person there, does not mean a fax machine won't sense noise on the line. A fax machine is much more sensitive, and cannot have a lot of noise or it will not be able to render the image at the other end correctly. So have your phone company and the recipient's phone company check the lines for problems.
There is also the chance that the two fax machines cannot get along. We have clients that we cannot use our fax machine for, because it always generates a similar error to yours. If we go to the other side of our building and use a separate fax machine on a different line, it goes through just fine.
The other half of the error is out of memory. If you have not tried these ideas, try them also: To gain extra memory, you can turn off Fax Storage, print fax messages in memory or cancel a Delayed Fax or Polling Job. In general, shutting the unit off will purge most everything out of memory.
Posted on May 13, 2008
dahaka
  • 347 Answers
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Posted on Jul 22, 2008
Healeyman
  • 1198 Answers
SOURCE: MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Posted on Apr 29, 2009
  • 4090 Answers
SOURCE: Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Posted on Nov 24, 2009
SOURCE: using MagicJack for faxing; however, Brother MFC
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Posted on Apr 13, 2010
OUT OF MEMORY
Hello laray7813,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
I am trying to fax and it says "poor line condition/out of memory" please help on what to do
> poor line condition
Disconnect it from the telephone wall-jack.
Connect a telephone-handset to that wall-jack.
Make a call to the FAX-number that you are trying to reach.
Listen. Do you hear "noise" or "static", due to terrible telephone-wires,
either from your location to your nearest telephone-exchange,
or from the target telephone to their nearest telephone-exchange.
> out of memory
Use the control-panel on the printer to delete "old" sent/received FAX documents, to clear-out some memory.
Apr 14, 2011 | Brother MFC-8460N All-In-One Printer
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Mfc-9840cdw scan poor line condition out of memory - how can this be solved. i feel so dense because it appears your site has already offered solutions but i can't even find them there!
Poor line condition / out of memory is almost always caused by poor line condition.
This is to say that there is a problem trying to send because the signal is not going through clearly enough.
This error can be due to either your fax machine or the receiving ends fax machine.
Try sending to other numbers as a test to see if it works for other numbers (you can use 1-866-685-8587 for the brother test line)
If you get the same error no matter who you send to, you may want to try another jack or telephone cable.
If you are using a splitter, try without the splitter.
Thanks,
Pat
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Nov 24, 2009 | Brother MFC 7840W Printer
Memory full
my machine says the memory is full.
also states.
NG poor line condition.
I cannot fax anything out.
Aug 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Can not send fax
Call your telephone provider. There may be noise on the line. Ask you telephone provider to perform a line check on your line. If there is a problem they can fix it on their end. Worst case senario, they come to location as you have poor lines or old lines into your home.
If you have Vonage or Comcast Digital phone service, you will want to slow down your modem speed on the fax machine. Your manual should show you how to do it.
Jan 09, 2008 | Brother MFC-8460N All-In-One Printer
Sending Faxes
This could be a cable fault. Get BT to do a line test for you (this is free). If that is OK, change the telephone cable. Perhaps this is on an extention cable? Remove it.
Aug 17, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother MFC Series MFC-8710dw MFC / All-In-One Monochrome Wireless Logo
1,444 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
