Question about Safe International Cobalt Em-016 Fireproof Home Safe Electronic Digital
How do i stop my cobalt safe from beeping? - Safe International Cobalt Em-016 Fireproof Home Safe Electronic Digital
How to reset code for a cobalt safe
Best thing to do is contact them at 1-888-535-2545 or e-mail them cobaltsafes@cobaltsafes.com
Apr 01, 2013 | Safe International Cobalt Sds-01c Drop...
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
Lost instructions to program new code in a cobalt safe model numbers874e
May I have the exact make and model so that I can find the exact instruction manual on how to program it.
Thanks.
Jul 26, 2011 | Safe International Cobalt S874c Steel...
I have a sandleford safe es23 if i punch the code in the safe beeps until i open it with the keys and disconnect the batteries. What am I doing wrong
we are looking after a friends place with one of these safe's in them, my daughter has pushed buttons and it wont stop beeping, we dont know the code or anything?? how do i stop it beeping??
Feb 23, 2011 | Sentry Fireproof Safe
How can i stop my sentry safe from beeping when i push numbers?
I have a 1459E model sentry safe. I was having the same problem. I removed the front electronic assembly, easily removed the circuit board, located the annoying beep speaker, then fliped the board over and heated up the two solder pins holding the speaker to the board, then it easily pulled away from the board. Speaker removed, I then op tested it by plugging it back the way I took it out......and voila! NO BEEPING!!! YES!!!
Nov 24, 2010 | Sentry Fire Safe - Safe - DS3607
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Safe International Cobalt Em-016 Fireproof Home Safe Electronic Digital Logo
183 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
