Question about LG E2250V-PN 21"LCD Monitor
HMDI to AVI???
I would like to use my LG Flatiron Wide screen [21 or 22 inch] monitor with my new desktop build. Since my MOBO has a HMDI out port and my monitor has none, I purchased a new cable with an HMDI adapter on one end and an AVI adapter on the other. Can't get any signal to go the this monitor. Is this setup wrong? Is it possible to do this?? Or am I in the market for a new monitor?
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
  • 16 Answers
SOURCE: lg flatiron wide screen
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. They will change the full package assembly or PCB. check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
samspelljr
  • 62 Answers
SOURCE: monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Posted on Jan 16, 2009
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
michael_grey
  • 365 Answers
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Posted on Jul 21, 2009
My th-42px80u Panasonic plasma tv has no picture or sound red light stays on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 17, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
LG Flatiron Wide is too bright until powered off then on
hii this is lisa and am expert to solve your issues that you are facing and call to this number when you are free +1(518)348-9393, we feel glad to help you to resolve your problem thak you
Oct 05, 2017 | LG L1915S 19" LCD Monitor
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
I have a flatiron m1921a, every time I connect it to my pc, I get a no signal on my screen, what do I do please?
Welcome to FixYa!
There are three reasons why you are encountering that problem, it's either the VGA cable, VGA port or the monitor itself. Please follow these steps for you to be able to isolate the exact problem.
1. Disconnect/Connect the VGA cable.
2.. Make sure that the VGA cable is properly connected
3. Try to use another VGA cable
4. Try to connect another monitor.
If you're already done with these steps and its still the same, most probably, the problem is with the VGA port. In that case, you will need to replaced the Motherboard itself.
Hope this information will help. Thank you for using FixYa.
Mar 14, 2011 | LG Computers & Internet
New 17" monitor, display is wide and short, not proper proportion
The monitor should have came with an installation or drivers cd. Use this disc to install the monitor specific drivers for your operating system. If you do not have the cd then you should be able to download them from the support section of your monitor manufacturers website. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | E-Machines 17" Widescreen Flat Panel LCD...
Oval to Round
Try changing to a different video resolution setting. Most monitors work well with the resolution set to 1024 X 768. I'm not sure what operating system you're using, but here's an example of how to do it with Windows XP...
Right-click on your desktop...then click Properties -- Settings --
You can try different resolution settings in the settings window.
Good luck...and I hope this helps!
Jan 28, 2008 | LG L1932TQ LCD Monitor
Lg flatiron wide screen
Nov 28, 2007 | LG L1915S 19" LCD Monitor
LG E2250V-PN 21"LCD Monitor Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
