Question about Dryers
When i turn on my dryer the filter light comes, it stays on constant.and its not getting warm,the filter is clean
The light does go off sometimes and comes back on,but doesnt get warm
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check all the thermostats for continuity.
Posted on Nov 30, 2012
SOURCE: I have a 2004 Nexxt Dryer and the the lint filter light is staying on.
Same problem
Posted on Jul 29, 2008
SOURCE: Candy Nova CDC 266 tumble
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
Posted on Dec 31, 2008
SOURCE: Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Posted on Jan 10, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: LG dryer check filter light
Have you checked the lint trap? If not this is what it is talking about. If you have then you should check your dryer vent line. Your lint trap should be on the inside of the dryer. If you need more help let me know. Also if you unplug the unit after checking what I said and the light still is one. Unplug it for 1 minute then plug back in this should reset everything
Posted on Feb 09, 2009
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
Posted on Sep 11, 2009
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
Lint filter light turns on and stops dryer before they are dry constantly
Your exhaust vent pipe could be getting restricted. Make sure it is clean and free flowing.Make sure your screen is clean, and also the ventilation port in it leading to the screen. The port could also be restricted.
Sep 03, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
We have a DLE3777W electric dryer. The check filter and cooling lights are coming on now all the time. It's drying but not as well as it has and takes longer. How do we turn off the cooling light? What...
if you pull your lint screen out and look down you will see like a metal piece with two screws, this is your sensor, more then likely it has lint/fuzz on it. I would suggest taking the cabinet(dryer) apart and cleaning it with a brush, lightly as not to damage it. Sometime you can get to it with a vacuum but if you are not careful it can be damaged. Here is a link that will help:
http://www.repairclinic.com/Dryer-Maintenance-Tips?red=Dryer-Repair-Help#areaunderlintfilter
Jan 09, 2011 | LG DLE3777 Electric Dryer
Cooling light stays on
remover the filter and run it see if that helps or remove the vent from the back
Apr 24, 2010 | LG DLE7177 Dryer
My maytag atlantis dryer will constantly run without heat. Also when you open the dryer door the light does not come on. Any ideas of what the issue is?
IF IT RUNS WITHOUT HEAT ALL THE TIME, YOU NEED TO CHECK THE THERMAL FUSE OR IGNITOR. IF IT'S GET WARM SOMETIMES AND TAKES A LONG TIME TO DRY YOUR CLOTHES, CHECK YOUR VENT TO THE OUTSIDE, RADIANT SENSOR, AND COILS
Jan 24, 2010 | Dryers
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
My Maytag dryer will not stay warm
replace gas valve coils kit
Aug 16, 2009 | Dryers
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
WTV74307GB
take the lint screen out and clean it with a toothbrush and warm soapy water. You may be using too much softner. If that doesnt work, the control board may be bad.
Mar 30, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
