First, are you running low on those ink colors? If not, possibly print cartridges need cleaning. If printer has separate print heads, they made need cleaning. Lastly, print head(s) may need replacement.
i dont think you where trying the right solutions. the mp250 catridge 511 can not be reset as far as i know. what you can do to get it to print is to long press the reset button. this disables the ink level check function and you can work. the procedure you stated is usually for resetting the ink absorber, not catridges.
If the resultsprint outlikethis,there are twopossibilities: 1.Redinkin thecartridgeruns out.Solution:injectingwithredink 2.If theredinkhas beenfilled,andcheckpatternis stillnotout, meaning thecolorcartridgeerror.Solution:replace thecartridges
According to Canon, the error that you are getting is related to the print head overheating. Usually the one connected to the color ink. What they recommend you to do is to replace the ink cartridge. Preferably the colored one.
Please do inform me on what happened to this.
If you want to print with color just give up print command i.e. color photos, color documents... etc.... When you give up print command your printer will print with define color.... thanks.....
Press Setting button on your computer four times, your printer display "u" and then press black/color. The printer start to print one page.
After printing the page put the paper on the scanner port and press black/color... that's it ..... thanks
Did you use Canon cartridges or generic ones? Sometimes if you do not use brand specific cartridges the printer will realize this and not print correctly. Also after you changed the cartridges did you calibrate the printer? If not, try calibrating 3 times and see if this corrects the problem. If not, it could be the cartridges...
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
