Question about Cardiozone Supersport Hr Club Commercial Treadmill
CardioZone SuperSportHR Club Fold-Away II ERROR 1
I've been receiving a "E1" error message when I try to start it. This happens after I turn the treadmill on, put on the magnetic ON/OFF key, and press START. The treadmill starts to move slowly then after about 10 seconds stops and a E1 message is displayed.
    Top Expert:
  • Cardiozone Master
  • 12,223 Answers
See the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
CardioZone SuperSportHR Club Fold-Away II ERROR 1 - 11_30_2012_6_42_10_pm.gif
Posted on Nov 30, 2012
  • peter_tata99
    peter_tata99 Nov 30, 2012
    Thank you Ernesto!
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My treadmill belt just stopped, message error E
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
Posted on Mar 13, 2010
I have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
1) adjust the speed sensor, and clean it, and tight the connector very well.see the diagram
2) test the main board output , for input voltage motor, if there are NOT the board is faulty see the block.
3) test the motor for input voltage, if there are the motor is faulty
God blesss you
Sep 19, 2012 | Exercise & Fitness
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
I have Yahoo mail and Yahoo messenger on my phone. I can communicate by SMS to someone's phone or by IM to someone's messenger. When I try to sign in I get an error message. How can I fix it?
I've been having the exact same problem - which appears to have started at the same time as yours! I can't find how to fix it anywhere!
Dec 12, 2011 | Yahoo Messenger
Why won't my browser allow me to use facebook? I've tried loading it with google chrome, internet explorer, & firefox. None of them work. When I try loading it in google chrome it gives me...
Hi, If this problem is still occurring for you and is only specific to Google Chrome, can you try clearing your browsing data to see if that helps? To clear your browsing data, follow these steps:
1) Click the Wrench menu in the upper right corner
2) Select "Tools"
3) Select 'Clear browsing data'
4) Ensure that check boxes for 'Clear browsing history' and 'Empty the cache' are selected
5) Click 'Clear browsing data'
I hope this helps. eibraz
Aug 03, 2011 | Facebook Social Network
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
My cardio zone club max hrt speeds up and inclines on its own. How do I fix it?
When i turn in my Cardiozone Club Max Hrt. it starts showing SI 2.
Feb 11, 2010 | Cardiozone Exercise & Fitness
Self Cleaning won't work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%TY
Feb 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cardiozone Supersport Hr Club Commercial Treadmill Logo
311 people viewed this question
Top Cardiozone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
