Question about Furuno GP31 GPS Receiver
MY furuno gps navagator is increasingly getting yellow horizontal lines on screen. Who do I send unit to for new screen?
hydetech
  • 113 Answers
SOURCE: furuno gps gp 32
The only place to get that screen is through a Furuno authorized dealer. The unit is sealed and gas filled to remain waterproof. You're best bet would be to send the unit in to Furuno for repair. You wont save much doing it yourself because the cost of the screen makes up most of the cost of the repair. They will also make sure that all the software is up to date for the new WAAS satellites that recently went on line.
Have you tried adjusting the contrast? On that model I believe you tap the power key while the unit is on and you will see 2 sliding scales on the screen, one for brightness and one for contrast. Up or down arrows select the scale and left or right arrows adjust it. If the contrast and brightmness aren't tied into the power key on that model, they're somewhere in the set up menu.
If adjusting the contrast doesn't help then the screen has most likely failed. This is commonly caused by old age, however repeated exposure to extreme heat or cold can cause premature failure.
Posted on Jan 26, 2008
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
physicistFL
  • 34 Answers
SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Posted on Jan 07, 2009
TechnoMarine
  • 132 Answers
SOURCE: Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Posted on Jan 16, 2010
  • 111 Answers
SOURCE: may i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
Posted on Jan 25, 2010
On the lcd display lines are apearing both horizontal and vertical,please help.
Your best bet is to contact Furuno. Replacing the LCD in those displays is very time consuming. I recommend writing your waypoints down or transferring them to a computer while you can still somewhat see the screen.
May 27, 2010 | Furuno GP32 Gps 4.5" Display
Unit will not power up. The fuse in the power line is good.
It is possible that their is a fuse inside the display. I would recommend sending the unit to a Furuno dealer to take a look at it. You can contact me: kevin@sun-me.net. We are a Premier Furuno Dealer that does bench repairs in house.
Apr 21, 2010 | Furuno 1650wf/Nt...
May i upgrade furuno 1920 gps/ploter with radar
Jan 25, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Furuno 1850 has water in unit, only noticed
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 06, 2009 | Furuno 1850WF Gps Fish Finder Combo...
Screen on GP 32 is washed out. Where can I get a new display
Contact your local Furuno dealer. That system uses the popular RD-30 display unit and should be rather avalible.
Sep 26, 2009 | Furuno GP32 Gps 4.5" Display
Furuno 1621 radar will not power up
With a voltmeter, verify that you are getting 12V at the plug end of the power cable. If so, check the fuses (there should be one or two fuse holders on the back). If all of that fails you will need to send it in to Furuno for repair.
Aug 22, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Mar 23, 2009 | Furuno 1833C/NT GPS Receiver
Screen fading with lines in it
I had the same problem with mine - it is 5 years old and very well used. I was told I could send it for repair, but opted to purchase a new unit. You can find service centers on line. The cost did not seem to justify being without GPS and then still having a well used system. This was the best solution for me.
Jan 05, 2009 | Furuno GP32 GPS Receiver
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno gps gp 32
Jan 25, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 GPS Receiver Logo
46 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
