Question about Hunter Fan Company 5/1/1 Programmable Thermostat
My hunter model # 44132 thermostat keeps flashing AUX and my heating system wont turn on
  • 24 Answers
SOURCE: my hunter thermostate keeps flashing a 4 and wont turn on !
hunter thermostats are not the highest quality. on the back of the thermostat there should be a not well identified reset button. You can locate and push this to attempt to fix the problem. Or purchase a new (i would suggest Robertshaw or braeburn) thermostat and install.
Posted on Dec 18, 2008
  • 1428 Answers
SOURCE: hunter prog thermostat 44360 flashing
Just hold down the two buttons for 5 seconds and it will be reprogrammed.
Good luck.
Posted on Feb 13, 2010
SOURCE: hunter programable thermostat
RE CO means Auto Recovery. In my users manual it states:
Hunter's Auto Recovery feature meets the Energy Star guideline for energy efficiency by allowing the heating or cooling system to recover gradually from an energy-saving set-point temperature to a comfort set-point temperature.
Auto Recovery calculates how early to turn your system back on. so that the room temperature is already comfortable by the start of the comfort temperature program period. Auto Recovery works in both heat and cool modes.
*When the thermostat is in Auto Recovery mode, the display will alternate "RECO" with time and the program indicator will flash.
*Auto Recovery can be disabled by sliding the Recovery switch on the circuit board to disable. (this is located inside the thermostate)
*Auto Recovery can be cancelers manually if HOLD/RETURN is pressed during the recovery process.
*Auto Recovery will be canceled and change to temporary manual override mode if the set-point is adjusted during the recovery process.
Hope This Helped!!
Posted on Nov 11, 2008
Benimur
  • 6966 Answers
SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
Replacing a trane weathertron with hunter 44132 i have r t o g y x2 b w wires where do they go on hunter 44312
T can be cut and capped, B goes to C (common) and W should go to W2 or E, whichever is present. X2 may be used in multistage heat strips if memory serves, cutting and capping it should be safe but changes in the wiring inside of the air handler may be required to accommodate this thermostat. If you like you can try connecting W and X2 (presumably white and black wires) both to the W2/E on the new thermostat but I would recommend checking the wiring inside of the air handler first. The rest of the terminals should be labeled the same.
Sep 22, 2011 | Heating & Cooling
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
Aux heat always comes on in heating (Ruud heat pump)
what type of system is it, if it's it Rheem the o/b needs to be set for B, if not check the freon charge, or thermostat, there will be a point where the aux. heat comes on when you turn it up, poss. only 4 degrees, is it a mercury stat or digital ?
Feb 01, 2010 | Ruud UAMB Air Conditioner
My heat wont come on
Did you try calling Hunter Tech support. I had same issue and the thermostat I had was not compatable with the system I had. They immediately recommended the proper model per the number of wires that were on the old thermostat. The 800# for Tech support should be on the package that the thermostat came in.
Dec 06, 2009 | Hunter Fan Company 5/1/1 Programmable...
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
I only have two settings. Which is which and how so?
I think you probably have a heat pump. Aux heat is electrical resistance heat coils that produce heat when the heat pump can not produce enough to keep the temperature up (caused by low outside temperature or a problem with the refrigerant system). This resistance heat can be switched on by the emerg. heat button. It also can come on automaticlly (sp) and will be indicated by the aux being shown on the thermostat. Sometime if you set the heat up several degrees by thermostat the aux will come on to help the system catch up to the desired temperature setting. The emerg. heat is a way to turn on the AUX manually. If you do not have a heat pump system then it is possible that you have a heat pump thermostat installed on a non heat pump system. Emergency heat and Aux are both the secondary.
Hope this makes sense1
Bob
Oct 17, 2009 | Ruud Central System Air Conditioner
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
My hunter thermostate keeps flashing a 4 and wont turn on !
Dec 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,175 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
