Viking 24 in. Professional Series VUD141  Built-in Dishwasher
Problem for Viking 24 in. Professional Series VUD141 (Ultra-Premium)...
Viking VUD141 advances through the cycles but won't drain water
By donnalegan on Jan 10, 2009
My dishwasher advances through the cycles and the dial moves, but leaves a LOT of water at the end. (and the dishes are not rinsed, they have a film on them,) If I physically move the dial (turn it to just on where it activates the draining), I can eventually get the water to drain out. (I have to do this several times to get rid of all the water.) As far as I know, there are no blockages in the lines or I assume it wouldn't drain at all.
Comments:
Mar 04, 2009
- Thank you...I think it must have been a partial blockage. I ran it multiple times and manually advanced it to drain until it finally resolved itself. It is now running fine and draining completely.
Same Problem
May 23, 2009
-   Bottom of unit remains full of water after cycle.-   Guest
Mar 08, 2009
-   My dish washer always has a lot of water in the bottom at the end of the cycles and doesn't seem to rinse my dishes, they always have detergent still on them!-   tinlizzy55
Solution #1
posted on Mar 04, 2009
Somewhat Helpful)
Kgt1962
Rank: Guru
Rating: 88%, 28 votes
The unit should be installed with a high loop in the drain line at the rear of the unit. If this is not in place it can cause the drain water to run back into the unit. If there is a partial blockage it could result in incomplete drain. Try disconnecting the drain line below the sink and run the unit to drain into a bucket see how it drains. would be a sign as to how free your drain line is.
It could also have defective drain pump
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Viking 24 in. Professional
Questions and Unsolved Problems for Viking 24 in. Professional
Do you recommend Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher?
Answer
Answer
Viking double oven The delay setting will not turn off or clear - when timer setting and off is... (More)
Answer
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't... (More)
Answer
water was shut off during dishwasher cycle not dish water will not work no water even though water... (More)
Answer
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking 24 in. Professional...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
