Question about Kenmore 63942 Dryer
Kenmore dryer Thanks for your response! I've tried what you suggested and that did not work. I have a parts booklet, could it be the sensor next to the flame?
  • 640 Answers
Ok im still with you ,,,,now what i need you to do is start dryer and listen to the gas vavle ,,it will click once than a couple of seconds it will click again,,than you should hear the gas light,,now your at left corner listing,,if you have no clothe in dryer the flame should stay on about 3-5 mintues..after the dryer heats up and shuts of it should come back on in about the same time 3-5 mintues,,listen for rattling or not clicking open the second time around,,if this is the case replace dryer vavle coils,,keep me posted,,onthejob..if the ignitor sensor were bad it would not light at all.they rearly go bad...
Posted on Jan 10, 2009
Kenmore 110.64622300 not starting
Unplug dryer and check the vent pipe to outside clear it and make sure vent is clear ro outside atmosphere.
take back off of dryer and check fuse. Fuse is located on blower housing next to control thermostat.
3399849-j2rqmywrjn05nkl43ld3f3b0-5-0.jpg If the fuse IS open (blown) then remove the filter housing and clean it as well. I have a home made video I did about heat problem but on my video I show how to check all that stuff: below that is my blog page smack dab full of all manor of stuff pertaining to your dryer. Please let me know if this heps. -PawPaw Dan Webster https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes
Jun 23, 2017 | Kenmore Dryers
My dryer will not start. It is Kenmore model# 110.62622101. There is power and the door clicks closed but it will not start.
Hi and welcome to FixYa, I am Kelly.
Try this first: Reach inside the drum and move the dryer drum by hand for about 1/2 revolution SLOWLY. Move the drum in a CLOCKWISE direction so you do not cause the ifler pulley to fly off. Then try a start.
If this does not makeit run then the next step is to make sure there is power at the push to start switch. Item 5 this link: (You accept responsibility for working on live circuits)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062622101/0582/0151200/P0110200/00001?blt=06&prst=0&shdMod=11062622101
Then you check the thermal fuse item 1 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11062622101/0582/0151200/P0110200/00003
Most likely the thermal fuse has failed.... the reason these fail is due to poor air-flow. Clean everything... wash the lint filter with vinegar and water, then soap and water. Vacuum all the internal ducting and the lint filter cavity. Use a folded wire coat hanger if necessary to knock the lint free so you can vacuum it out. Go outside and check the thru the wall vent flapper for blockage. THEN replace the thermal fuse. Turn on the dryer and check air flow with the rear ducting disconnected. It should push a relaxed hand gently away from the duct connection. If you do not have this kind of air flow after an avid cleaning and lint removal session... there is most likely a problem with the blower wheel spinning on the motor shaft / broken fan hub. Blower wheel / fan is item 37 of this link:
The other possibiliies are the motor switch and the timer. Most of the time the problem is the thermal fuse failure due to lint build up.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Kenmore 72982 Gas Dryer
Do you have access to the instruction booklet for the Kenmore 16324 Gas Grill i just took it out the box after a year and i see its no instruction booklet :(
Sears Parts Central has the Owners Manual for your grill. Actually, the correct Model Number is 1411624. I have provided a link to the manual that you can download and print.
http://www.managemylife.com/mmh/owner_manuals/1877/KENMORE-Grill-Gas-L0512095?brand_name_search=14116324+KENMORE
Happy Grilling!! And please be kind enough ot rate my response in finding the Owners Manual for you. Thanks!
Apr 10, 2011 | Kenmore 632 sq. in. 16324
Dryer wporks fine, no heat. is there a fuse or a heating element out? kenmore gas dryer 110.70812990
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Dryers
Appears all buttons are working and door closes correctly. dryer will not start up. was using-turned time setting knob to left-dryer would not start back up again. have done nothing to fix.
You have a burned out motor or their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
Dec 25, 2010 | Kenmore 64882 Electric Dryer
Dryer not heating up but working.I'm not sure how to bypass thermal fuse to test it is the problem. thanks Lonnie
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent. NO REASON in the world to play with the thermal switch.
Dec 24, 2010 | Kenmore Dryers
My Kenmore dryer will only run for about 2 minutes and then will shut down and i have to reset it every few minutes until the clothes get dry. What would be causing the dryer to just shut off like that.
Sorry to read about your problem, I hope this helps you out.
you have a overheat problem, or a motor problem. I suggest you call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Kenmore Dryers
Will run for a few minutes then quit. I;ve cleaned the filter, put the belt back on but I can not put a lot of clothes in it with out it throughing a belt
I have a Kenmore Model 68972892 Dryer. It will only run if you hold down the start button and the heating element does not get hot. I have checked certain sensor by jump them with by pass wire but nothing changes. Can you give me some suggestions? Thank Dave;
Nov 21, 2010 | Kenmore 64892 Electric Dryer
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
