Question about Canon i860 InkJet Photo Printer
Fix USB003 error on Canon 1860 printer
This is a paper jam error but there is no jam and have followed the resume, trun off and then back on procedure still get the same error
    Problem Solver:
  • 12 Answers
Get a new printer.
Posted on Nov 29, 2012
SOURCE: Canon Muiltcast F60 "Check Printer" error
F60 Alarm Blinking "Check Printer" "Press Resume Key"....tried everything and fixed it by pushing the darker gray piece which lies below the opening where the memory card is inserted. I mean it when I tell you I did everything! And as soon as I pushed on that piece my alarm stopped blinking lcd error message cleared and my printer is perfect....go figure!
Posted on Sep 04, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
  • 13433 Answers
SOURCE: Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Posted on Jun 12, 2009
My printer says there is a paper jam, yet I removed the paper jam and pressed resume. How can I fix this?
Try power-cycling the printer: Unplug the printer, wait 10 seconds, then plug it back in. It should clear the paper jam error message. Hope this helps!
Mar 12, 2011 | Canon Pixma iP6000D InkJet Photo Printer
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have got error 5100 what does this mean
Hello
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank. Resolving the error is a quick process that only requires a few standard troubleshooting procedures.
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon printer to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
But in some other canon printers,Error code 5100 indicates that the waste ink absorber has reached maximum capacity. The Canon i860 printer uses the waste ink absorber to keep ink residue off the printer heads and internal printer components. To resolve this error code, the waste ink absorber must be cleaned out and the error code message needs to be reset.
Open the top of the printer.
Locate the waste ink absorber pad on the right side of the inside of the printer. Grasp the pad and pull up to remove.
Take the waste ink absorber pad to a sink. Run warm water over the pad and wring it out to clean it. Wring the excess water out when done cleaning.
Clean the waste ink absorber compartment with a tissue or cloth.
Set the waste ink absorber pad on a dry paper towel or clean cloth to dry.
When the pad is dry, place it back into it's compartment in the printer.
Close the top of the printer.
Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button.
Press the "Resume" button four times
Press the "Power" button. The error code is now reset.
Nov 13, 2010 | Canon Office Equipment & Supplies
Canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Mar 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
281 people viewed this question
old marine
old marine
