Question about Mavic CrossMax SX Front Wheel 08 - cycle parts
I have a 2009 Mavic crossmax sx front wheel and would like to convert the fonrt axle to standard quick release is thier any axle conversion kits available
4 Suggested Answers
SOURCE: freewheel on Mavic SSC-SL turns with tire/wheel rotation
Not sure if you ever got a response. I can help with half the issue. These Mavic SSC-SL wheels are a breeze to disassemble the rear hub (I've done so many times). I have these wheels on road bikes AND cross bikes. You DON'T need (nor want to use a vise). Yes, the one side is a 5 mm allen key. While the other side seems like it has nothing, you can actually (with your hand) simply grab the black axle and pull it away/off the hub. It will be a bit stubborn, but trust me, it comes off. There is an O-ring on the inside that simply keeps it sealed and on. Once you have that part off, you now insert a 10 mm allen key. With the 5mm in the other side, you can now twist and remove the entire axle and freehub. Careful, the freehub will now come off the axle, exposing the seals, a washer, AND 2 pawls that are in place by springs. Be careful not to lose the springs.
There's not much to it. Now simply inspect, lube and reassemble. Btw, this is also how you change your wheel from a Shimano hub to a campy hub.
Hope that helps.
Regards,
Corey
Posted on Mar 01, 2009
  • 1138 Answers
SOURCE: IS there a manual to guide me on how to service
Try this site:http://www.parktool.com/repair/byregion.asp?catid=57&imageField2.x=19&imageField2.y=8
Posted on Oct 19, 2009
piloti951
  • 3 Answers
SOURCE: front wheel on Mavic crossmax sl is constantly
Floss the spoke crossings at each hub interface with clean rag...DONE!!!
Posted on Aug 08, 2010
I want to buy 1 of MAVIC KSYRIUM SSC SL SPOKE KIT REAR, DRIVE-SIDE, 272MM and MAVIC KSYRIUM SSC SL SPOKE KIT FRONT, 281,5MM SILVER, I want to know if you have in stock this kits and help to me to find road...
Hi, Edurado for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://roguemechanic.typepad.com/roguemechanic/2012/07/mavic-spokes-and-parts-in-stock.html
Mavic Ksyrium SL SLS Replacement Spokes 4 81
http://www.tech-mavic.com/tech-mavic/uk/sources/Produits/ROUTE/Roues/KsyriumElite/KsyEliteSpokeReplacement.pdf
Where to get older Mavic Ksyrium SSC SL Spokes The Paceline Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2015 | Road Motorcycles
Mavic Crossmax SLR rim split. I want to order a new rim for the rear wheel. How do I go about it?
Either trust your local shop, or call one of the e-bay or Amazon vendors, such as Nigara, Bike Wagon.
Sep 16, 2014 | Mavic Crossmax Slr Disc Mountian Bike...
Can i go from a 1" rear axle to a 3/4". I have a 250mm wheel and tire and want to buy a conversion kit for this, but all the conversion kits im seeing have 3/4" axles w/them
Hi Anonymous, you would have to fabricate 3/4" adapters to go into the axle slots unless they come with the conversion kit. Good luck
Apr 21, 2013 | 1993 Harley Davidson FLSTF Fat boy
Noise on freewheel rotation when moving fairly fast, I think the pawls are hanging up but how do I get it apart/
Too take the Freehub off of the hub body is fairly simple on Mavic. You will need either Mavic Mineral oil, a lightweight mineral oil or other very light lubricant when you are done with cleaning. This can be tricky to find and you may need to enlist the help of your local bike shop to get some or the equivelant.
Here is the direct link to the Mavic service instructions with nice clear pictures and "how-to's".
Jan 03, 2011 | Mavic Crossmax Sl Disc Wheelset
Can you convert Mavic Crossride 9mm QR to larger
You want to convert to a 15mm through axle? You won't be able to unless you change out the whole hub to the larger one. If you had a through axle and wanted to go down to a 9mm, some manufacturers have reducers for that. double check - call a local bicycle repair shop in your area.
Mar 29, 2010 | Cycling
I just bought a set of crossmax st wheels and cannot figure out how to put the centerlock rotors on. The tool will not fit over the axel housing and I cannot figure how to disassemble them.
I don't know exactly what you are looking for but I found a couple of links that might help you:http://www.mavic.com/medias/tips/pdf_dl/FTSX_0.pdf and http://www.mavic.com/medias/tips/pdf_dl/2008_wheel_user-guide.pdf Here is where I found these:http://www.mavic.com/mtb/tips/user_guides.aspx
Oct 31, 2009 | Mavic CrossMax ST Mountain Bike Wheel
Front wheel installation
The lever on the quick release skewer goes on the non-drive side of the bike.
Dec 25, 2008 | Mavic Ksyrium Elite Wheelset
Mavic CrossMax SX Front Wheel 08 - cycle parts Logo
59 people viewed this question
Top Mavic Cycling Experts
Michial Gueffroy
vidiot1961
Level 1 Expert
Paul Bade
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
