Lap top not working
Powering down immediately i power up any solutions ?
    Novelist:
    Champion:
  • 233 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 30, 2012
Benimur
  • 6966 Answers
SOURCE: Toshiba Satellite M45 Power Problem
Your concern (auto shutting down) with Toshiba could be caused by excessive power drain by some of the attached devices such as the WiFi, LAN among others. On the other hand, it could also indicate that the battery is already weak and constantly requires charging and at times eats up most of the power from the adapter leaving nothing for the motherboard to use. In some repairs I have done, switching off / or removing entirely unneeded devices correct the problem. In some instances, auto shut down is caused by dirty/clogged airducts/heatsink of the processor, failing blower/fan and/or poor ventilation.
Of course, it could not be ruled out that internal problem with the power supply/regulator to have caused the shut down. Alternately, there are some viruses and malwares that could trigger shutdowns.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
  • 32 Answers
SOURCE: no power to lap top
make sure the other side of the adaptor is also pushed in fully...i hope this can help
Posted on Dec 23, 2008
joecoolvette
  • 5660 Answers
SOURCE: gateway lap top is not getting any power, the
Suggest you take out the AC adapter (Charger), and remove the battery. Wait one minute, Replace the battery, plug the AC adapter back in. (AC adapter to surge protector, 'Natch)
See if it will turn on. Hold the Power On button down, until it does.
Should it not turn on, I suggest you have a problem with the DC Power Jack. This is the round opening in the laptop, where the AC adapter goes.
These little jack's undergo a lot of stress. The body of the jack, is just a tiny bit larger than the hole itself. The body is made of plastic. Let me show you an average example of a DC Power Jack,
http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1476209
That jack is about a fingernail width in length, 3/4th's of a fingernail in height, and half a fingernail wide. (I'm holding one in my hand now. I repair laptops)
The round hole has a metal sleeve, (Or a piece of flat metal at the end of the hole) The metal sleeve is the Negative connection.
There is a thick metal pin in the center. This pin is the Positive connection. Your laptop uses DC electricity.
(Your AC adapter converts AC electricity into DC electricity. A flashlight battery is an example of stored DC electricity. Laptop batteries are stored DC electricity)
Sometimes when an AC adapter is plugged in, the plug is bumped.
Sometimes this 'bump' can break the DC Power Jack. Break the middle pin loose, or the outer metal shell.
Also, if you look at the photo, you will see flat metal 'pins' sticking up. In relation to how this jack sits on the motherboard, it is upside down in the photo.
The 'pins' go down through the motherboard, and are soldered on the backside.
Sometimes the solder joints for these 'pins' can be broken. You either get an intermittent contact, or no contact at all.
Sometimes this isn't the case. Just due to normal plugging and unplugging of the AC adapter, can cause an issue.
This due to a bad design of the laptop motherboard.
The following is a crude illustration of that bad design.
Think of the laptop motherboard as being a 1 foot square. (It isn't)
Now along one edge, attach a 2 inch square. (It's actually all one piece though)
Now place the DC Power Jack on this 'Peninsula'.
The 'Peninsula' becomes cracked, right where it meets the main body of the motherboard. There are traces, (Think very flat thin copper wires), that become stretched and break.
This laptop motherboard design flaw is kept quiet. Laptop manufacturers have to replace the entire motherboard, when the laptop is under warranty, and has this issue. Also, replacing the motherboard just buys the laptop owner some time. The motherboard will break in this area again.
Could be all wrong about this. 'Google' your laptop name and model number and add -> Motherboard Issues <-, or add ->
DC Power Jack problems.
Posted on Apr 13, 2009
jassji
  • 104 Answers
SOURCE: dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Posted on Jul 16, 2009
  • 7 Answers
SOURCE: How do I reset the power on password on my Compaq presario C300?
1.Reinstall the whole thing...
2. Enter the Bios and attempt to reset. (Unlikely)
Posted on Jan 16, 2010
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
My lap lap top was placed on wet area, now the screen is black although the computer power light is on, what shall I do
It sounds like some of the moisture has entered the laptop and caused problems. First of all take the battery out of the laptop immediately and power it down, make sure you do not try to power it up until you have attempted to dry the unit. I would recommend covering any holes/vents in the chassis of the laptop with masking tape and placing it in some kind of storage container buried in dry uncooked rice for at least 24 hours. Hopefully this will draw any moisture from the laptop and prevent further problems. In the meantime, if you are desperate to access the files you might want to extract your hard disk and connect it to another computer. I wouldn't recommend this if it can be avoided, as it will require moving the laptop around which may help work moisture further into the system, the moisture could also be affecting the hard disk, if it is and you attempt to power it you risk losing your data forever.
Mar 20, 2014 | Acer Computers & Internet
The lap top power supply goes off automatically while working sessions
It seems the game giving lots of pressure to your problem and there might be some dirt which is blocking your processor to cool down, So first I'll suggest you to Clean the Processor FAN dust properly and apply heat sink paste on top of the fan.
Aug 04, 2012 | Acer Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
My lap top is in power save and my moude and
Hold the power button down until the Laptop shuts off completely and then pull the battery out for 30 seconds as well as the AC adapter.
Replace the battery and boot the Laptop
Jul 21, 2009 | MPC Computers ClientPro 365 PC Desktop
Dropped lap top now wont boot up
Jul 16, 2009 | Dell Latitude D600 Notebook
Plugged in not charing, power available 92%
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Jun 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Flat screen is going out
Replace the VGA or HDMI (whichever you're using) Cable, and the Power Cable (one of the two can cause this problem, or even worse, fry it!)
Then,...... try connecting the monitor (with new video and power cables to another pc that you know for a fact is working correctly... the problem could be your power supply, motherboard, etc..
If that doesn't work.....Return The Monitor if you can..........cuz if the above doesnt fix your problem, ........then you'll know the monitor is bad......but don't assume that til you try my solution k!
Apr 19, 2009 | Computers & Internet
Prob. 1unit shuts off by itself/ prob 2.back is cracking again
IT SOUNDS TO ME LIKE THAT YOUR UNIT IS OVER HEATING WHICH IS VERY COMMON WITH CHEAPER LAP TOPS. YOU CAN GO GET A LAP COOLER FROM STAPLES OR A LOCAL ELECTRONIC STORE THEY ARE NOT VERY MUCH. DID YOU DROP IT?
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Open Questions:
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
